I'm sorry for the difficulties you're experiencing in viewing the Desktop correctly when connecting a computer to the TV. Unfortunately, there are no such drivers available for TV to make it compatible with a computer.
Please understand that the image from a connected computer will not display in full screen because of the difference between the display resolution of the television and the available resolutions on the computer. Setting the WIDE MODE (Zoom) option on the television to Full 1 or Full 2 will stretch the image to fill more of the television screen but will not fill the entire screen. This is normal operation.
I have searched online and found that 1024 X 768 will provide better experiencing than other resolution. It is required to set the resolution in the computer before connecting it to the TV. Please install if graphic card updates available from the computer manufacturer so that it will give option to select resolution in some cases.
Thanks for understanding. Please let me know if you require any clarifications.
SOURCE: Is there display drivers available for my NEC
There are no display drivers for the NEC Plasma TV model PXT-42SX1B. It is up to your Display Adapter or Video Card to assign the monitor a resolution. Your monitor also has a menu setting for the resolution which must be set to the same as your computer's resolution. Hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
