The problem as you described is have to do with your vibration pump. Is a very popular problem with vabrating pumps. They work purfect but as soon litle air is trap at there exit valve which is consist from two springs and one small teflon ball then you have the problem you have described. Manytimes repeating the descaling progress can solve the problem and in other cases if you desasemble the vibrating pump and brush it out from scale deposits and water dirt and rust then again you can solve the problem. If both the above can not give any results then you need a new pump. Many times it worth the effort to replace the pump from the first time so you will avoid all the desconfort and have results at once.
