SOURCE: what size shaft seal is in a dream maker eclipse
Your spa should have the aquaflo pump which uses a PS-200 seal.
http://www.ussealmfg.com/pdfs/ChooseThe%20RightSeal.pdf
SOURCE: I have a leek on white screw thread above motor on
You probably only need a new union o-ring and it's a simple fix.
Regards,
Ian.
http://hottub.synthasite.com
SOURCE: We own a dream maker
If it is only leaking when the pump is running, the problem is usually the shaft seal on the circulation or jet pump. This should be easy to check.
