mine won't turn on at all... I checked the batteries, it just won't do anything....what do you think that is?????mine won't turn on at all... I checked the batteries, it just won't do anything....what do you think that is?????
camera wont turn on and lens is open and zoom out.when I hit power button the yellow lite comes on for just a sec then goes out. ive replaced batteriescamera wont turn on and lens is open and zoom out.when I hit power button the yellow lite comes on for just a sec then goes out. ive replaced batteries
lens is 1/2 way out and nothing happens no matter shat I do... camera shop said it's probably off the tracks. cheaper to get a new camera they said.lens is 1/2 way out and nothing happens no matter shat I do... camera shop said it's probably off the tracks. cheaper to get a new camera they said.
I tried several new batteries and no matter what the camera won't turn on. Sometimes it's considerate enough to tell me batteries depleted. Usually not; just the little green light goes on for a while and then turns off. I tried several new batteries and no matter what the camera won't turn on. Sometimes it's considerate enough to tell me batteries depleted. Usually not; just the little green light goes on for a while and then turns off.
i have the same problem, i bought it in march 2008, changed the battery pack with reachargables and it has never worked since i bought it from asda's and now they have stopped selling them, didnt have my reciept and there was nothting they could do!!!
You can't post conmments that contain an email address.
Hi, The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
You'll need to either take this to a qualified repair shop or replace. Depending on the cost of the repair (Which I would guess as significant) it will more than likely be more economical to replace.
yes me too! one side of my lens hit the ground and is stuck. it wont come out and my camera also automatically turns itself off once i try to start it. i think you shoudl go get your lens fixed...mines stuck and wont go in or come out
I had the same problem the lens wouldn't retract and it would only stay on long enough for the logo to show...I found out my lens changed slightly cooked to oneside I gently moved the lens to center and now it works great...look at the lens and see if this helps
Hi:
First of all, with that behavior, your lens are stuck. Probably the problem was on the assembly. Try to disassemble and assemble them again.
Regards
