Clean the outdoor coil and the indoor coils if its cooling now it will surley need cleaning. Clean it good and them put a good filter not a cheap filter the you can read the newspaper thru. A pleated one and the indoor coil will stay clean.
Make sure the outside unit is working, both fan and compressor inside. If both of these are coming on and working, then your problem would more than likely be low/high refrigerant charge. You can also check the air flow inside and make sure it's blowing normal. Weak air flow can point to a dirty or clogged indoor coil which would have to be cleaned by taking the cover off of the coil, possibly moving flue vents out of the way, and taking the small cover off of the inside coil depending on if it's a upflow or downflow system. Hope this helps or at least points you in a better direction, good luck!
