The igniter switch is located just below the knobs, If you pull the knob off and look in the hole that the shaft comes through, you will see the igniter switch, To replace them you will need to remove the cook top and flip it over and remove the cover section so that you can get to the back of the controls
Here
is a tip that I wrote to give details about why your cooktop will not
spark to light the burners..
Cooktop
Range Stove spark ignition does not work
heatman101
Thank you. This appears to be more than a home fix it since the cooktop is installed and caulked onto the counter.
The igniter continues to spark several times a second. Is there a danger in this? Thanks.
