SOURCE: mICROWAVE WILL NOT HEAT
23 month old. MMV4205BAS MAYTAG MICROWAVE. WILL NOT HEAT AT ALL. Lights work, turn table rotates, blower works. Everything else seem to work fine. Haven't done any troubleshooting.
Don H
SOURCE: MAYTAGE MICROWAVE MMV5100AAB-SWITCHING BREAKER WHEN STARTING
is there a way to over ride the main board start button so i will know if the board is bad. or away to test this?.
SOURCE: Maytag Microwave Oven (MMV4205AAW) won't power on.
You will need to replace the 20 amp. ceramic fuse inside the unit. This is real easy and the fuse only cost around $10.00 You will find a break down of your unit at www.partselect.com just enter your model number and a break down will come up. Your part number is PS2052772. You can also locate where the part goes. Good luck.
SOURCE: i have a new microwave oven,model#MMV4203DW &
Chances are you have a failing high voltage transformer.
Often there is a "mini-manual" hidden inside the unit behind the control panel
or hidden on the left side behind the grille, which is very helpful when
troubleshooting, &
testing.
At
our Web site, we have a video available
showing how to remove a typical over the range control panel assembly in under 5
minutes.
See these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Here is a link you or someone you know can use for high
voltage section test help, but read the safety warnings first:
http://www.gallawa.com/microtech/xformer.html
You can find links to helpful exploded
view diagrams and part ordering help
here.
I'd recommend that your bookmark this link to your favorites.
Accessing some parts may require you to pull
the oven from the wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two
people since the microwave can be heavy and awkward.
You can download Maytag
owner's manuals and installation instructions here.
We're happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: HOW TO REPAIR MAYTAG MMV4205AAW MICROWAVE NOISY
unplug and take apart and more than likely something is hitting the blade or it has slid down the shaft and is hitting the motor or the cover if u pull the blade off and plug in and it dont make the noise then the blade is hitting something if the motor is still making a noise then the motor needs replacing
Dead appliance, power on wall outlet.
YOUR
SAFETY IS PARAMOUNT!
Attempt
this only if you are competent.
If
your appliance has absolutely no functions at all, remove it from the
mains supply, remove the case and see where the mains lead goes in to
the appliance and follow the cable until you find the main fuse.
ONLY
USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual
cause of this fuse failure is the door switches are contaminated or
sticking. Check the door switches before putting power back on to the
appliance.
Hope this helps.
