I looked at the washer drum online and the holes seem pretty small there are (from the outside looking in some groves that it may have gone thru.}
Have you taken a flash light and with someone else rotating it {drum) by hand gotten a general idea of where it may be sticking thru by sound? then looking closely at that area for a protruding bit of wire? then grabbing i with a needle nose pliers or a wire cutter and pulling it out? I'm not sure how technical you are cuz taking it apart to get to the drum may be a challenge.
Hope this helps you.
SOURCE: Manual for Eurotech MLD110
(copy and paste this link in your address bar)
http://www.ersatzteilonlineshop24.de/suche_ger2.php?model=MLD110&hersteller=Eurotech
SOURCE: Eurotech front loading washer, noisy on spin cycle with load.
My eurotech washer has an inner and outer stainless steel drum. The inner drum is supported in the back by cast aluminum supports. (like many other models). The cast aluminum carodes and weakens and breaks. You may find pices of this in the strainer. Not hard to replace and not expensive but very difficult to get the part. Eurotech has been out of the part for months.
SOURCE: The spin cycle will not run on the regular wash.
Check the pump drive belt. It may have come off.
Sounds like the motor is spinning but the pump belt isn't spinning the pump.
Pull the front cover and look under the machine for the belts.
K
SOURCE: Machine, Model EWC 177, stopped working in the
Yes! There is a fuse inside or circuit breaker!
SOURCE: my eurotech washer is making a horrible noise
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
