Question about Toshiba Computers & Internet
Cord plug on lap top loose inside computer - Toshiba Computers & Internet
  • 813 Answers
Change the pin
Posted on Aug 24, 2008
6ya staff
SOURCE:
The power cord will not stay plugged into my computer. Unfortunately this is the 3rd time it has happened. The previous two times it was under warranty. The cord was replaced and that worked for a...
If it is that loose it is worn out in the case on the mother board now this is a simple replacement of a little plastic adapter. They are relatively inexpensive but the repair is not. It is complete removal of parts from the lap top to get to this part. If not done correctly your lap top will suffer serious issues and may have to have the whole board replaced. I strongly advise that you take this in to a repair shop or make it work by gently take a pair of pliers "Needle Nose" and gently squeeze the tip I mean gently so as to not break the wiring seal or anything else. Do it just enough to stay on the pin on your lap top.
Take this in if you can afford it and get it done properly is my first option. You are responsible for it if you go with that suggestion of a gentle squeeze not much very gentle and once until it stays in that is all. This is what I would do first it is cheaper to replace another cord than a board repair. John
Jan 17, 2011 | Toshiba Satellite A105-S4244 Notebook
Video cord for lap top
All you need to do is plug the video cord in and right click on an open space on your desktop. On the pop up menu select the Intel TV wizard. Then follow the on screen guide to use your TV as your second monitor.
Dec 13, 2008 | Compaq Presario Notebook
My lap topwill not turn on.
Try to check if your AC adapter has a light itself. If it the light is off. Then try a known good adapter. If the AC light is green, then try to wiggle the cord from the port and see if it ain't loose. Try to also check if the AC pin is not bent or broken.
Nov 25, 2008 | Dell Inspiron 6000 Notebook
Computer can't find printer
Your using an Ethernet cable and your not on a network. You most likely need a USB cable, or connect the computer and printer together with a router. How are you accessing the internet from home?
Nov 19, 2008 | HP Laserjet 2605 Printer
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Lap top not turning on
Try removing the battery, waiting 30 seconds, then plugging it back in. Plug in power cord and try to turn it on.
Feb 02, 2008 | HP Compaq Evo n610c Notebook
Computers & Internet Logo
20 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
