Sony KV-27FV16 TV Logo
Posted on Jul 02, 2011
A dog chewed up the power cord on my Trinitron TV model KV-27FV16. Is it possible to get and install a replacement myself?
3 Related Answers
Anonymous
  • 579 Answers
  • Posted on Dec 31, 2007
SOURCE: blank screen on sony trinitron tv
The problem with this model is the large parts due to poor wave soldering. Locate the transistor Q605. Using a small wattage soldering iron melt the solder and add a little solder to all the large parts in the area. Small wattage = 15 to 30 watt. Stay away from the surface mounts they are not the problem. I resoldered the following: D647
Q605 C690 D645 D620 R691 Q691
These parts are located on the main board, the one the power cord connects to. Carefully press the clip on the left side of the board (as you look at it from the rear of the tv) carefully pull the main board back and out of the rails. You will find the parts on the right side of the main board about 2 inches over 2 inches down.
Anonymous
  • 187 Answers
  • Posted on Jun 23, 2009
SOURCE: Sony Trinitron TV - Keeps Blinking
Try this link
http://www.agoraquest.com/searchbb.php?addterms=all&forum=all&sortby=p.post_time&submit=1&term=trinitron%20blinking%20picture
pls rate my suggestion....
Anonymous
  • 17 Answers
  • Posted on Jun 06, 2010
SOURCE: Sony FD TRinitron WEGA,
Just went thru the same problem with my sony kv-34. There are two IC's on the D circut board located on the left side looking from the rear. If you can solder 18 pin IC's without making a mess it is possible.If you have a friend thats real good with a pencil tip solder device. I recomend putting sockets in where the IC's were as you won't have to worry about overheating stuff next to the IC's.Do a google search: Sony led flashes ad select the second hit in the list.
Good luck
Rich
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 • Vacuums
1helpful
Sony Triniton not powering on
If the lights don't come on the tv ,try to connect the tv to the other power point
and check if it powers on, if its does not power on then its the problem with
fuse inside the tv replace the fuse and check its works ...and also test the power chord for continuity ..
Good luck...
Sony KV-27FV16 no sound
Try going into the audio settings part in your menu and select reset audio settings.
No sound or picture
I'm not sure if you solved your technical issue or not, but if your TV is still broken, I would be interested in buying the door that covers the AV inputs. This door is on the front of the TV. Unfortunately, mine broke, and it's been difficult to find a replacement. If you are interested, I can be reached at (612) 801-5752 or by email at [email protected]. Thanks.
Please Help
call a tech your tv needs to to be repaired the problem is in the power supply and related circuit.good luck.
3helpful
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
No sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
1helpful
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
TV solution
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
