Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Same problem - at same time (1 year after purchase) as guarantee was ending. Engineer "fixed" the problem - and one month later the same error code has appeared and i am unable to use the dishwasher.
Any solutions? Or recommendations for a 60cm integrtaed dishwasher to replace this one?
I have the e4 error code too!
Left machine alone for 3-4days and it worked again for 1 cycle, then e4 error code again.
Any suggestions?
E4 relates to anti - flood activated. There may be a small leak from the door or the sump, which collects in the base tray underneath and eventually operates the alarm. Lying the machine on its side made the water drain out, the alarm goes off, and it works for a while again - until it fills up and alarms again. You need to find the leak, probably the door seal dirty, to fix this. Also - never open the machine door when it is hot and running, or cold air will expand in the machine and water will flood into the base tray, as the tank is a sealed box!
