Please remove the webcam and then UNINSTALL the program from the PC. Now download the driver software that is applicable to the OS in your PC which is not specified by you. Now after downloading RUN the program and when it indicates to connect the webcam you can do so as it will message that a new harrdware is found . This will be installed within the PC.
if there are issues check with another PC to confirm if the webcam has errors.
Testimonial: "Did As Suggested & My Webcam Now Works! Fantastic!"
1st You download Webcam Driver.
LifeCam VX-1000
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Microsoft Camera Drivers for Windows XP Vista Windows 7
Place the product installation CD in the CD drive of your computer. The installation wizard will start automatically. Follow the installation wizard prompts.
Plug the USB connector at the end of the LifeCam VX-1000 connection cable into an available USB port on your computer when prompted.
Place the LifeCam VX-1000 on a flat, level surface, or hang it from your computer's monitor. Continue following the wizard prompts until the installation wizard finishes.
Click the "Start" button, then click "All Programs" on the Start menu.
Click the "Microsoft LifeCam" folder icon in the list of programs on the Start menu, then click the "LifeCam" icon. That opens the LifeCam VX 1000 software and completes the installation process.
