The D-390 allows you to choose if you want the camera to retain your settings or to default the settings. In the camera menu, there is a function called “All Reset”. If the selection is ON, the camera will default all settings each time the camera is powered on/off. If the selection is set to OFF, the camera will remember all of the settings that have been made.
Issue: How do I reset the camera to its default settings? Solution: Procedure for resetting the camera to its default settings PowerShot SD960 IS.
Resetting Settings to Their Default Values - PowerShot SD960 IS.
1. Turn on the camera and press the <MENU> button to open the menu.2. Using the button, highlight the yellow (Set up) tab.3. Using the button, select [Reset All..] and press .4. Select [OK] and press .
Settings cannot be reset when the camera is connected to a computer or to a printer.
The following cannot be reset:
Shooting mode
The [Date/Time], [Language], [Video System], and [Time Zone] options in the (Set up) menu
White balance data recorded with the custom white balance function
Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
The image registered as [Start-up Image]
Perform the reset operation to initialize the camera’s setup (page 136). After that, configure each setting. If the language selection screen does not re-appear when you turn the camera on, it means that the camera’s built-in memory management area has been restored. If the same message appears after you turn power back on, contact your retailer or a CASIO service center.
1. Press MENU to enter SET UP menu.
2. Press right or left arrow to reach the settings.
3. Then go on to view the menu
4. Find Reset Camera Settings.
5. Reset your camera.
6. Turn on the camera
7. Date/Time settings will appear.
8. Set your date/time.
Hi, Please follow the steps below to reset the setting to default...
Shooting mode
The [Date/Time], [Language] and [Video System] options in the (Set up) menu
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
PROCEDURE 1. Initialize the system. a) Enter the TEST mode. b) Select "3:ROM UPDATE" and press SET button. c) Next, select "5:SYSTEM INITIAL" and press SET button. d) The following message appears. SYSTEM INITIALIZE START ... PUSH OK KEY? e) Press SET button and System is initialized. "SUCCESS !" appears on the monitor. 2. Write firmware. Update the firmware version" Write the firmware. If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
The ALL RESET function works two ways. When it is set to ON it restores the camera to the default settings once the camera is powered off. You can still put in custom settings, but they will be reset when you turn the camera off. When it is set to OFF the camera remembers the settings you have entered. For example, if you want the camera to always start up in the 3:2 aspect ratio you would turn ALL RESET to OFF and then select the 3:2 quality setting. The 3:2 setup will be there every time you start the camera up until you set ALL RESET to ON. When ALL RESET is set to OFF the camera will accumulate all of your setting changes, so it is recommended to reset the camera occasionally.
The camera can be set to retain all your camera settings each time the camera is turned off and on. Press the OK/MENU button. Then press the right arrow to access the Mode Menu. Press the down arrow to highlight the SETUP menu. Press the right arrow to highlight ALL RESET, and then press the right arrow again to highlight ON. Press the OK/MENU to save this setting and return to the Mode Menu. The camera will now retain any settings such as Quality each time you turn off the camera.
