Cameras Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera will not come on with battery inserted. When battery is in charger it never reaches stage where light on charger turns green. It remains red. It blinks at first then stays solid red... Nikon d40x. Do I need a new battery or charger? Or is camera broken?
Anonymous
Level 2:
  • Expert 300 Answers
  • Posted on Jun 30, 2011
Anonymous
Expert
Level 2:
Answers
300
Questions
Helped
98779
Points
787
When the charger blinks it indicates is either charging or trying to charge.
A solid red light indicates a bad battery.
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
1helpful
What does the red light on the battery charger mean?
Usually, it means that the battery is low on charge. Once the battery reaches a suitable charge, the light should turn green.
3answers
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
12helpful
Green & Yellow light on 14.4V charger
It sounds like your battery is bad.
replaced.
6helpful
Both green and yellow lights come on and stay on.
replaced.
11helpful
What does the charge plus+ light and the green light mean together
replaced.
5helpful
Need to know what the lights mean on a makita dc24sa charger
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
Battery pack or charger
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
2helpful
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
