Question about Whirlpool AD50USS Dehumidifier
How do I install a hose so this humidifier drains automatically?
    Brigadier General:
  • 4,736 Answers
Remove the water collection bucket from it's holder and depending on which bucket style you have on your model, will determine where the hose connection is on the left side of the bucket. It will either have a drain hose connector behind a screw off cap or it will be behind a slide off drain hose connector. In either case, you can use a garden hose, no longer than 5 feet to drain the water into a floor drain or a sump pump collection bucket. You will need to drill out the center of the drain hose connector using a 1/4" drill bit, before connecting the hose. Do not damage the out portion of the hose connection, as it will leak.
If you need further information, I have included a link to your Owner's Manual, that you can download and print for future reference. http://www.appliancefactoryparts.com/content/pdfs/156177-1.pdf
Hope this helped you. Please let me know.
Posted on Jun 30, 2011
    Champion:
  • 230 Answers
Look at the drain pan, it might have a garden hose connection that you might have to knock out, mine is not the same model but it may be similiar, and then run it to a floor drain or such. Good Luck
6ya staff
SOURCE:
Trouble with disposing of water. I have it hitched up with hose, but humidifier insists on filling the interior bucket. Help please
For the hose to work the unit must be elevated somehow so that the bucket will not fill. Or somehow the unit must be higher than the end of the hose. If you put the hose down an open floor drain that should suffice.
Jul 12, 2015 | Soleus Dehumidifiers
What size of hose or tubing do I use to connect directly to my de humidifier, to drain directly into a drain. Thanks. I have model DDR451
A 48' long piece of garden hose will work fine. Connect the female hose connection to the unit's hose connector and be sure that the hose slopes down and straight to the floor drain. Drainage thru the hose relies entirely on gravity. Be sure to set the humidity extraction level low (32 - 35%) for continual operation.
I hope this helps you and thanks for choosing FixYa..
Aug 18, 2011 | Danby DDR451 Dehumidifier
DeLonghi dehumidifier hose by drain tray leaking
I think that I am having the same problem, but I'm not sure that this tube needs to be plugging into anything. However, my humidifier seems to be draining out of this tube rather than from the tray into the bucket.
Jul 14, 2009 | DeLonghi Dehumidifiers
Looking for floor drain hole cover that accepts a hose
yep home depot get one with holes and a plastic tie will keep it in place
Jun 16, 2009 | Goldstar DH304 Dehumidifier
Dehumidifier collecting water in container
If you have the hose drain tube connected, drainage will defer to it first. If you remove the hose drain tube, the place where it connects to the drain pan drips into the container instead.
Sep 17, 2008 | Maytag M7DH65B2A Dehumidifier
Kenmore 54501 Dehumidifier
Clean the hose (it's full of black gunk)
Jun 30, 2008 | Kenmore 54501 Dehumidifier
Problem with draining water through hose
I bought one of the FDL70S1 Frigidaire dehumidifiers today for my shop, and found that the $5 hose I bought to drain it through the floor wouldn't tighten down completely, allowing the hose to twist and wobble, a sure indication that it was not water tight. Simply adding a second washer, as described in another answer here, allowed me to tighten the hose sufficiently to produce a tight fit with no play between the hose and the dehumidifier. It hasn't leaked. I know it is a threads-per-inch issue, and I am stumped as to why Frigidaire would supply these units with a different thread pitch than the standard GHT (garden hose thread) 3/4" - 11.5 tpi. The threads on the unit appear to be 3/4 NPS - 14 tpi. Go figure!
Jun 03, 2008 | Frigidaire FDL25P1 Dehumidifier
Drainage bypass to hose not working
I taped down the float in the container so that the unit would not shut off when the conainer filled up. The water now is going through the drainage bypass .
Oct 05, 2007 | Maytag M3DH30B2A Dehumidifier
Missing hose adapter
It might be a problem since these units were made by Fedders for Maytag which is now owned by Whirlpool :inhale: but I found part number FD9520-010 "drain hose". If not, a length of dishwasher drain hose with a male garden hose fitting on one end would work fine
Aug 15, 2007 | Maytag M7DH45B2A Dehumidifier
Whirlpool AD50USS Dehumidifier Logo
976 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Perry Mellott
Perry Mellott
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
