First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
the 19LE3300 has no RCA audio Outputs, the only way seams to be able to found the schematics and found where to connect an Jack connector to the audio signals.
Hi again..OK,if this the case here is the new solution...
since your TV has :2 x HDMI, SCART, AV, Component Video, VGA-sub, USB 2.0, connections,we will use the SCART pluf to get Audio output for your Headphone..you need to buy an adapter called " RGB Scart Male to 3 RCA AV Female Adapter Converter that can easily be found any electronic Market..one example as found eBay URL is below..
http://cgi.ebay.com/RGB-Scart-Male-3-RCA...
After you get this adapter,you need to carry the audio signal from SCART to your Headphone with a RCA (white/red ) cable..Assuming that your headphone has RCA audio input..otherwise you need another adapter or cable RCA to 3.5mm Headphone jack..
please let me know the result..I will do it everything possible to make it work..for sure..but you need to help me too..
Regards.
Hi,we are just trying to help you eagerly to solve your problem..Believe or not ,if I had the opportunity to visit your home I will make it work one way or another..
Even though I have not seen the service manual, I insist that TV's SCART connector which has 21 pins and "2x Audio Output " pins should be in it..there is normally no electronic equipment in the world which has half way wired SCART connection.Please look into wiring of SCART plug in manual again ,you will see what I have meant..This is a must for SCART connections..(unless mfg states somewhere in the manual..as "SCART IN only" )
To test it , just plug the SCART to your Stereo system/RECEIVER (you may need SCART to 6xRCA cable ) and if you properly connect IN/OUT plugs you will able to get the audio signal of the TV thru stereo..that's why I recommended 2 $ value "RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter" with IN/OUT switch on it.
"Would you please let me know the result ?.. if you have a RECEIVER and if you want to make the test of course."
My regards..
the 19LE3300 have a strange behavior there are no outputs for audio and the SCART connector don't out put any audio signals. we are not anymore in analog TV in France and that is certainly the reason of this behavior. In fact there is no solution to solve the problem only to modify the programm. Finally I got the service manual for the 26LE3300 whose chassis is the same as the 19LE3300. Viewing the schématics it's impossible to modify something to get it work.
Since you were not able to give me a solution, would you give me my money back . as a token of appreciation for what guys you have been tried to help me, I will give you the service manual if you want it.
Thanks
