Hi
Did you check the connections in the carriage if there is little amount of ink on the contacts? if not then clean it well with a dump cloth and try to re-install the old printhead it will sure accept it. If not then the other way is to change system date of the printer first and then try again.
DO RATE MY SOLUTION
** Fixed **
I got my problem solved by followed below article steps.
http://printer-driver-download.us/hp-inkjet-2800-driver-download/
Thanks
Thanks this worked, although it still didn't show up until I cleaned it very thoroughly, both the print heads and the region on the printer where they are inserted. I also recommend you wear gloves.
