Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
