Question about Quantaray 28-90mm f/3.5-5.6 for Pentax
I have a Nikon D70, and a Quantaray lens (28-90mm). I have had this camera for about four months, and it has been working fine with the lens. When I received the camera, the aperture ring moved, but the aperture would not change. Left locked on 22, it worked fine. Until today, I was hiking, and knocked the camera by accident on a tree. It was a hard knock , I believe, because now, the aperture will change when you rotate the ring, and the camera will not take photos on any aperture. It says FE E. Please help me, I love this camera and will be really upset if I cannot fix it. Thank you
  • Quantaray Master
  • 3,289 Answers
In order for the aperture to be controlled by the camera's program or primary and secondary control knobs, the lens must be set to the smallest opening - or highest number value f stop. The aperture must be operated by the ring if it is not left in the smallest opening position.
The FEE code you are seeing refers to a communication error between the lens and the camera body. Sometimes, simply removing the lens from the body and reseating it to the body will solve the problem. While the lens is off the body, carefully inspect the gold colored contacts on the lens and mating contacts on the camera body. Remove any dirt or debris found, being careful not to allow it to fall into the camera - or land on the back glass of the lens.
I found another explanation and possible remedy that stated:
"A flashing "FEE" is an improperly set aperture ring in 99.9% of all cases with this error message (i.e. user error). In very rare circumstances it can be caused by a damaged aperture ring (small lug broken from back edge) that can't "tell" the camera it is at the minimum position. If the aperture rings on the lens is set to minimum aperture (highest number) and locked there, but you still get a FEE error, it's possible that sloppy tolerances are causing the lens aperture ring to not move the little switch at the 8 o'clock position (on the D70 lens mount) as far as necessary to get a proper indication of minimum aperture. Try to see if the aperture ring (while locked) will move slightly when mounted on the camera to clear the FEE error.
Another remote possibility is that the little switch at the 8 o'clock position mentioned above is not functioning properly (sometimes they get dirty). Try "exercising" it by moving it back and forth with your finger, then try the lenses again. Usually FEE has nothing at all to do with CPU contacts (with a reverse engineered third party lens anything is possible I suppose), but it doesn't hurt to clean them to eliminate that possibility."
You can also try a different Nikon compatible lens. If the trouble is still present, the camera may need to be returned for repair. If the the problem goes away, then the issue is tied to the lens itself. This would mean the the lens needs repair.
I hope this helps and good luck! Please rate my reply - thanks!
Posted on Jun 30, 2011
6ya staff
SOURCE:
FEE message using Quantaray for Nikon lens
Turn the aperture ring on the lens to its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
Jan 26, 2013 | Nikon D Cameras
Quantaray 600-1000mm Telephoto Zoom Lens FOR NIKON work with D3100 in all modes?
The lens is a manual focus lens. It doesn't matter which mode you have the camera in, you'll still have to focus it yourself.
Nov 16, 2012 | Quantaray 600-1000mm Zoom Lens
Is Quantaray NF AF work with Nikon D3000
Quantaray lenses are available with a variety of mounts. Assuming you get one with a Nikon mount, then yes, it will work with a Nikon camera. However, unless the lens has a focusing motor, it will not autofocus on the D3000. Some Quantaray lenses have such a motor, some do not.
Jul 31, 2011 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Can I use Quantaray AF 28-90mm f/3.5-5.6 in a NIKON D5100? Thanks.
Quantaray makes lenses with a variety of mounts for a variety of cameras. A lens with a Sony mount, for example, will not fit onto a Nikon camera. Assuming the lens has a Nikon mount, it will fit on the D5100. However, the D5100 requires the lens to have an autofocus motor. If the lens does not have such a motor then it will not autofocus. It will still work fine as a manual focus lens.
Jun 19, 2011 | Quantaray AF 28-90mm f/3.5-5.6 Lens for...
Will my Quantaray AF 70-300mm 1:4-5.6 LD TELE-MACRO(1:2) going to work with the Sony Alpha cameras? The A55 in particular?
Quantaray makes lenses with a variety of mounts. A lens with a Nikon mount, for example, will not fit onto a Sony A55. If the lens has the Sony mount then it will work fine with the A55.
May 03, 2011 | Quantaray Cameras
Will my quantaray tech-10 NF AF zoom lens (for me
Yes, with caveats. The autofocus won't work on D40/D60/D3000/D5000. The metering may not work in all modes on all cameras. Since you didn't specify which camera, I can't give you a better answer than that.
I have 30-year-old Nikon lenses working fine on my D90, but without metering. And the old lenses date before the invention of autofocus.
Nov 27, 2009 | Cameras
Quantaray QDC-NK i TTL Digital Flash Module
The Quantaray Digital NK Module has a small tab on the side of the raised boss that the 8 pins sit on that prevents it from mounting on the QTB-9500A. It's intentional- the NK Digital Module is made for newer Quantaray flashes only. You'll need the older-style AF NK Module to attach to the QTB-9500A.
Apr 06, 2009 | Quantaray QDC-NK i TTL Digital Flash...
Quantaray 100-300mm Lens for Nikon
Yes the new nikon D60 needs lens with a built in a/f motor. Your lens will go on and work but you will
have to manual foucs
Sep 30, 2008 | Quantaray Zoom 100-300mm f/4.5-6.7 for...
My nikon d70 won't turn on and the battery if fully charged
The black spot i suspect was the CCD or processor failing. Checkout Nikon customer support re this.
Aug 05, 2007 | Nikon D70s Digital Camera
Quantaray 28-90mm f/3.5-5.6 for Pentax Logo
201 people viewed this question
Top Quantaray Cameras Experts
Doberman
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
