Televison & Video Logo
Posted on Jun 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My user manual was destroyed in a flash flood. ( TV not involved) However my cable equipment was destroyed so everything must be reprogrammed to work properly. Without my users manual I am finding I can't accomplish this task. Thus I need a replacement for my LG 32LH30 TV
alexander woolfolk
Level 2:
Guru:
  • Expert 276 Answers
  • Posted on Jun 30, 2011
alexander woolfolk
Expert
Level 2:
Guru:
Answers
276
Questions
Helped
110086
Points
753
OK if you go to the LG web site you will see under SUPPORT you can download user manuals. Look for your model TV and you can get a PDF file of the manual. Try this link and click on the PDF icon to download manual.
http://www.lg.com/uk/tv-audio-video/televisions/LG-lcd-tv-32LH3000.jsp
What is the best way to reprogram a Yamaha WX5 Ewi
Reprogramming a Yamaha WX5 Electronic Wind Instrument (EWI) typically involves adjusting settings, assigning functions to different keys, or customizing parameters to suit your preferences. Here's a general guide on how you might reprogram a Yamaha WX5:
  1. Access the Menu:
    • Turn on your Yamaha WX5.
    • Navigate through the menu options using the buttons or controls on the instrument. Refer to your WX5's user manual for specific instructions on accessing the menu.
  2. Select Parameter to Edit:
    • Once in the menu, find the parameter you want to edit. This could include things like breath sensitivity, pitch bend range, or assigned MIDI channels.
  3. Adjust Parameters:
    • Use the controls provided on the WX5 to adjust the parameters. This might involve turning knobs, pressing buttons, or using a combination of controls.
  4. Save Changes:
    • After making your adjustments, make sure to save your changes. The WX5 typically has a save or store function within the menu. Confirm the changes and save them to the instrument's memory.
  5. Refer to the Manual:
    • Consult the user manual for your specific Yamaha WX5 model. The manual will provide detailed information on navigating menus, adjusting parameters, and saving changes.
  6. Connect to a Computer:
    • Some advanced customization may require connecting your WX5 to a computer using MIDI. You can use Yamaha's dedicated software, if available, to reprogram certain parameters.
  7. Use External Sound Modules:
    • If you're using external sound modules or synthesizers, some customization may need to be done on those devices as well. Refer to the manuals for your MIDI equipment to ensure compatibility and proper configuration.
  8. Explore Advanced Settings:
    • Depending on your proficiency and the complexity of your WX5 model, you might explore more advanced settings like custom MIDI mapping or adjusting sensitivity curves.
Remember to approach reprogramming with caution, especially if you are not familiar with all the settings. Make note of the default settings before making changes, so you can revert to them if needed.
Always refer to the user manual specific to your Yamaha WX5 model for accurate and detailed instructions on reprogramming and customization. If you're unsure or uncomfortable with the process, consider seeking assistance from Yamaha support or experienced professionals in electronic wind instruments.
My Panasonic CT 2521 HDB needs to be reprogramed
Reset it to its factory default, and then reune it. Refer its user manual for details.
1helpful
T L C television what is the purpose of the USB port on the side of the 32 inch flatscreen TV. My copy of users manual has been destroyed can one download to a laptop computer using nthe USB port.
The USB port on TV's is to record a program onto a Flash Drive/Thumb Drive,
which then you can plug the Flash Drive into your Computer to watch or download it on your PC.
I hope this helps you.
If so please leave a vote or comment.
MobileJB
Multi processor LC6200 type 520 user manual destroyed in recent floods.?where to download from
try forum. electromaniacs.com or partstore.com they may have the manual for your processor. good luck
1helpful
2answers
Where can I get a manual mine was destroyed in a flood
You can download user manual copy of Zenith XBR413 from HERE.
Click above link and download manual free copy.
Thanks.
My remote no longer works and I can't get the menu to come up so that I can reprogram my channels and get all of my cable channels. Right now I only get basic cable channels, even though I have full...
You will have to disconnect the TV from the AC outlet for a few seconds(10-20) then reconnect the TV and press power. You should get the start up menu after you get a picture. What you have to do is use the vol up/dn , chnl up/dn keys to select the autoprogram setting after chosing from cable or antenna signal. the enter key should be one of the DVD keys either play or stop or some other key, you'll have to experiment a little with it. There is an owners manual available at retrevo.com in case you need it, but I am posting a brief description stated in the manual on how to do this. Chapter Summary: The STARTING SETUP function makes installing your TV/DVD easily...It leads you the Language selection, TV/CABLE selection and auto channel memory automatically...... Make sure that the antenna or cable TV system connection is made... ENTER CANCEL... Starting setup... Press POWER...The starting setup function begins and the Language setup menu appears on the screen...Press or to select your desired language, then press ENTER...... Users also looked at: Press or to select the “AUTO CH MEMORY”, then press...... 5S10101A [E] (P13-23) 23... This TV/DVD is equipped with a channel memory feature which allows channels to skip up or down to the next channel set into memory, skipping over unwanted channels...In addition to normal VHF and UHF channels, this TV/ DVD can receive up to 113 Cable TV channels...When shipped from the factory, this selection is in the CABLE position...... Press or to select “TV” or “CABLE...... Press MENU in the TV mode, then press to select option...... Cable TV chart... Press or to select “ADD” or “DELETE”, whichever function you want to perform...... The chart below is typical of many cable system channel allocations...... Press or to select “TV/CABLE...... Press press... TV/CABLE selection Automatic memory tuning... TV/CABLE AUTO CH MEMORY ADD/ DELETE... or... to select “ADD/DELETE”, then...
My prima tv suddenly says
You took the TV out of the mode for either satellite or cable and it need to be reset . check the user manual for the setting.
You didn't give model number for the unit/ I may be able to get you the instruction for you to reprogram the tv.
Looking for a User's Guide and Handbook for my Husqvarna Viking Platinum 730 sewing machine. My manuals were destroyed in a flood.
You can find a similar manual from (http://safemanuals.com/user-guide-instructions-owner-manual/HUSQVARNA/VIKING%20190-_E).Hope you will be satisfied.All the best.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
