It is possible that your game is scratched up enough that you can't play it directly on your xbox 360... BUT you might still be able to play it is you can save it to your Xbox 360 hard drive. You might need to try it a few times to get it to read and work but try following these instructions for installing the game from your CD directly onto your Hard drive. You will still need to have the CD in your Xbox 360 to play but it will be reading from your hard drive if you can install it. Good luck:
To install a game on your hard drive
loadTOCNode(2, 'moreinformation');
- Insert the game disc into the disc drive.
Note After you insert the disc, the default option is to automatically start the game. If this happens, exit the game and return to the Xbox Dashboard.
- From the Xbox Dashboard, go to My Xbox.
- Select the game you want to install.
- Press the Y button on your controller.
- Select Install to Hard Drive.
- A progress indicator appears while your game is being installed on your hard drive.
Note Installing an Xbox 360 game might take 12 minutes.
To play a game from your hard drive
- Select the name of the game you want to play.
Note The game disc must be in the disc drive, even though you have installed the game on your hard drive. The console will automatically play the game from your hard drive, but the disc has to be present.
To delete a single game from your hard drive
- Insert the game disc for the game you want to delete from your hard drive.
- Go to My Xbox, and then select the game you want to delete.
- Select Delete from Hard Drive.
To delete multiple games from your hard drive
- On your console, go to My Xbox, and then select System Settings.
- Select Memory.
- Select Hard Drive.
- Select Games.
- Select the game you want to delete.
- Select Delete.
To clear space on your hard drive
If there is insufficient space on your Xbox 360 hard drive, you will receive the following message:
Not enough space to install this game. It needs [space needed] free space to install. Do you want to clear space? (YES/NO)
Click YES to view a list of games that you can delete. After you clear enough space on your hard drive, you can install the new game.
