HTC Touch P3450 Smartphone Logo
Anonymous Posted on Jun 29, 2011
My wireless doesn't work nor my bluetooth - HTC Touch P3450 Smartphone
Anonymous
Level 2:
Sniper:
  • Expert 64 Answers
  • Posted on Jun 29, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
64
Questions
Helped
16597
Points
258
Is it on? make sure by going to bluetooth menu>turn on blue tooth.
Wifi is grayed out
Turn off Bluetooth in settings and then tap wifi turn off then back on. Wifi should now be working
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Does the Sony VAIO vgn sz430n come with Bluetooth and, if not doesn't, does it matter what Bluetooth dongle I get?
I would start by pulling up your laptops configuration and see if it has a bluetooth card installed, most newer laptops do but it all depends on how the laptop was configured when ordered or purchased. Check your connections section and see which wireless cards are installed.
My wifi turn itself off
Its been said that if you hibernate your PC too long,
when you resume windows your wireless is 'confused'.
Try restarting or hibernating again and resuming immediately after.
Sometimes this works for me, sometimes it doesn't.
Also, if your bluetooth isnt working either, you could have a problem with your wireless.
Check for updates and update BIOS and anything related to your computers wireless assistant, connectivity, etc.
re-install the wlan card driver, just download it again dont bother uninstalling
hope this helps
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
I'm using a Toshiba L505-10W. recently i've installed windows 8 consumer preview. my wireless doesn't turn on and the flash cards doesn't work either. realized that even my bluetooth d
The drivers for the hardware don't exist for windows 8. You need to format. turn on holding the 0 key. follow steps to set to factory defaults, save your pictures and documents first cause this will erase them.
Hi, i have a compaq 6710b notebook,s/n CNU7502TGW....i installed windows7 on previously existing xp,since then the bluetooth ,the wireless asst. and the firngerprint sensor are not working.I...
Not all drivers that worked previously on your laptop on xp would work on windows 7. Basically it has different built so manufacturers releases drivers for certain os as long as it support it.For your laptop download your driver here for windows 7:http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3356622&taskId=135&prodTypeId=321957&prodSeriesId=3356620&lang=en&cc=us
Hope that i helped. Regards.
I am Looking for Sony VGP-BMS77 VAIO Rechargeable Bluetooth Wireless Laser Mouse drivers but i can only find the vista one and it is telling me that it will only work with vista and I need to work on...
Windows 7 and Windows Vista were built off of almost the same code. Try using the windows vista drivers anyway. If it doesn't work, you can always uninstall them.
2answers
My ipod is just playing without the sound carrying through to the speakers. I dont know how to make it work?
Verify there is nothing plugged into the headset port, including headsets, headphones, or adapters.
Original iPhone only: While on the Home screen, adjust the volume buttons. If you see the icon below, indicating that headphones are attached, there may be debris in the headset port:
To remove debris in the headset port, try connecting a pair of headphones to the headset port and then remove the headphones. Repeat this several times.
If you have paired with a Bluetooth headset that is nearby, either use the headset or turn Bluetooth off (choose Settings > General > Bluetooth).
If that doesn't work, try restarting the iPhone. Hold the Sleep/Wake button until "slide to power off" appears. Slide to power off your device. When it is off, press the Sleep/Wake button to turn it back on.
If restarting the iPhone doesn't resolve the issue, try restoring the device.
1helpful
2answers
How to install wirless mouse
It depends on the wireless technology used by the mouse.
1. Infrared
If your mouse used Infrared for communicating with your PC, you will have to place an Infrared receiver on your desk, in line with the mouse you want to install. You will definitely have to install the drivers supplied with the mouse/Infrared receiver.
2. Bluetooth
If the mouse uses Bluetooth, first you either will have to install a Bluetooth dongle on your PC/Laptop (if it doesn't have Bluetooth integrated) or activate the Bluetooth on your PC/Laptop. Then, using the Bluetooth software supplied with the dongle or PC/Laptop, search for new devices and choose the mouse to pair with. You may have to install the software provided with the mouse for if to work.
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
