Computers & Internet Logo
Posted on Jun 23, 2017
My 5400 no longer connects to the internet. The internet light is out. The router is working on my intranet okay. When I try to connect, I am asked to submit a UID & pwrd. Using the same ones I have always used. I have 2 servers and a PC connected directly to the modem and a wireless PC. None work. I have swapped out ALL cables. I had qwest check the line and I checked at the line-in port (normal). Wassup? The ISP tells me to buy a new router!
5 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Aug 05, 2007
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Anonymous
  • Posted on Jun 22, 2008
SOURCE: Connecting my westell 6100 modem to my router
linkseys Wireless G broadband router need to hook up to Verizon router/modem
Anonymous
  • 15 Answers
  • Posted on Jan 13, 2009
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
Anonymous
  • 27 Answers
  • Posted on Feb 23, 2009
SOURCE: Use a Qwest Actiontec GT701-WG router with a different ISP?
Yes, if the other isp is also providing dsl services, but you will have to configure the device the other isp will not help you with that.
but its really not that difficult.
Anonymous
  • 145 Answers
  • Posted on Apr 10, 2009
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
How to connect intranet users to the internet in NAT address pool mode
Aha, you can visit the http://www.huanetwork.com/blog/, there are your answer, the example configuration for the AR router.
The latest news about Huawei networking products
Cannot wireless connect Samsung DVD Blue Ray to Net Flix
set the ip address to be detected automatically in the tv network settings.
What you need to know is the encryption key used on the Wi Fi
If you do not know it it might be on the case of the Wi Fi access point device.
Otherwise you will need to log into the router by typing the router's ip address into an internet browser on the working computer.
1helpful
Cant connect to my router netgear
http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html
  • 1Before you connect Nintendo Wii to wireless Internet, set up your Wii console according to the manufacturer's directions.
  • 2Turn on the Nintendo Wii and wait for the main menu to appear.
  • 3Using the Wii remote, point and click on the small Wii button in the bottom left corner.
  • 4Select Wii settings.
  • 5In the bottom right corner click the black square with the number 2 in it or use the right directional arrow to go to the next page. When you come to "Internet" click it.
  • 6To connect Wii to the Internet select "Connection Settings."
  • 7On the next screen select the first connection that says "none."
  • 8On the following page, when given the option for wired connection or wireless Internet, select "wireless."
  • 9Now it's time for your Wii to search for a wireless connection. To do this choose "search for an access point."
  • 10Press "okay" and find the name of your wireless Internet. If it's not on the first page, arrow down until you find it. If you need a password to access the Internet, you will be asked to enter it. Click okay.
  • 11Click save and okay so the Wii remembers the wireless Internet connection options for the future.
  • 12Finalize the Wii Internet connection process by testing the wireless connection.
  • 13When Wii's wireless Internet test finishes successfully, you're ready to play Wii online.
  • Read more: Video: How to Connect Wii to Wireless Internet ' eHow.com http://www.ehow.com/video_5168009_connect-wii-wireless-internet.html#ixzz1f6B48YnB
    I cannot get online wired or wireless. I have configured the wireless and it says I am connected with excellent strength, however, I cannot get on line. When I get the error, the corner icon says local...
    Go through your Network Connections, and use the Wizard to make a new connection. Follow the wizard to connect to the " Internet."
    Other thing to check is, On the router, do you have the WAN connected to your internet service.?
    Otherwise, your connection to the router will be great, but the router will have no service to access.
    Laptop shows wireless signal is available. DSL cable, all lights burn green on the router. Can access google, when I try to access a web address, the page will not load
    in explorer > < tools > < internet options> <delete> all your temparary internet files.
    now try accessing google.
    On the router the only lights should be blinking are the connected ports Wan to the WWW the conneccted Lan ports to the intranet.
    Powercycle the router and the reset button on the back.
    Try a direct wire and see if the access to the net works.
    Reconfigure the WIFI of the router by the instruction book
    Cannot get the router tom connect to the intranet
    If you connect the computer directly to the modem, does it work?
    If that works then the modem is working.
    Now connect the computer to the router and the modem to the router.
    You will need to open the set up page of the router to check the settings of the router.
    You can set up the router without the CD also.
    It is very easy.
    Click Here for step by step instructions about how to set up the router
    Westel 327W no longer accessing VPN
    It sounds like your company has changed some settings for access into thier local intranet. Your IT guy will have to figure out what's wrong, becuase he would be the one with the knowledge of your companies settings. Perhaps they changed the shared-key, or something in the security settings.
    Another note: If you have recently changed/upgraded any installations of firewalls or internet security software, check to make sure it's not blocking any of the IP address or ports you need open to access your company network.
    Blitzz BWA611 Router
    a router shouldnt need to dial for a connection, go to open your internet browser and go to tools, then internet options, then click connections tab and select never dial a connection so as to stop internet explorer looking for a modem connection
    2answers
    Blitzz Router
    Ah, you can no longer use the modem or the Blitzz screen to connect to your Internet connection. You'll need to patch another Ethernet cord from the router to your Ethernet port on your computer and it should automatically connect. If you still get prompted to dial, open up Internet Explorer and ignore any prompts to dial and then click Tools, then Internet Options, then click the Connections tab at the top, then click the selection to Never Dial a Connection. Confirm your choice by clicking OK and then try browsing the Internet like usual.
    Top Actiontec Computers & Internet Experts
    Jesse Walters
    Jesse Walters
    NOEL
    NOEL
    Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
