SOURCE: BUSH ID - HD TV
Try Checking your remote and make sure it did not short out by taking out the batteries and see if it continues turning on and off. if so then i would recommend replacing the remote. if this does not work try putting tape over the ir receiver and see if it continues, this will check for interference.
SOURCE: tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
SOURCE: Cannot tune analog channels on Bush 32'' LCD TV
Hi I am Vortash not a set I have worked on but suggest that the solution will be in the user manual , if you have no user manual try this site http://www.safemanuals.com some of the downloads by adobe pdf file are free others reasonably priced I hope this is of help Regards Vortash
