The UPS is either off, has a dead battery or is dead. Does the UPS power anything at the surge only outlets? If it doesn't, it's off or dead. Turn it on and check again.
The Omni 100 VS does not have a user-replaceable battery or other parts. If the battery or UPS is dead, replace it.
I hope this helps.
(when the UPS is off but connected to power, the battery should charge.)
• Unlock all of the channels on the TV by
entering "6688," which is the factory reset code. This code resets
the TV to original factory settings. Once this is done, you will have to go
through the initial setup.
• Call Omni technical support at (416)
260-0047. A technician can help you troubleshoot the television as the problem
may not be the child lock. You'll need to know the model number and serial
number of the TV.
•Take your television to a TV repair shop if you
are still unable to unlock the TV. The problem may be with the wiring, so the
repairman may have to rewire the TV
