SOURCE: Kenmore Elite HE5T Steam - Won't Start, No error codes
I had the same problem, but due to the great info on the internet, I found the problem and solution. I have been able to temporarily fix it until I can get someone out to repair the plunger. The site below has the details. http://applianceblog.com/forums/view_topic.php?id=730&forum_id=2&jump_to=4559
Karen
SOURCE: kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
SOURCE: Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
SOURCE: Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had
the same problem. One morning I opened the doors to a hot fridge and
burning plastic. The light housing was sizzling hot - much of the unit
literally melting away. Another hour or two and it could have been
much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes
of patient talking, I learned that Sears (or Kenmore) have issued what
they refer to as a "flash warranty) on the light fixture kit (Kit #
6871JB1423N) which in effect, for this part only, extends the factory
warranty from one year to three years. I may even be able to have a
factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
