Yamaha RX-V3800 Receiver Logo
Posted on Jun 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have just connected zone 2 speakers on my yamaha rx-v3800, however I can not get any sound to them due to the BiWiring operation being on. (I am running me fronts in bi wire) In order to get sound to my zone 2 speakers I need to manually turn the BiWiring mode off in the advanced operation section at the front of the amp. Can this be avoided? Can I still have biwired fronts and run zone 2 ?
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Jun 28, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2764920
Points
24828
Read up on the myths and legends of bi-wiring (BUY wiring) and redeploy those amps and extra speaker wire to Zone 2 where they'll actually serve an audible purpose.
http://forums.audioholics.com/forums/showthread.php?t=678
Yamaha RX-V3800, for Zone 2 input is set to DVD, can not change it to CD
Hello Clark, I pass the link to download the user manual of your Yamaha, on page 115, everything about the use and multizone connection appears and on page 117 it indicates how to select the sound sources for zones 2 or 3
I recommend that you read this part of the manual carefully, to get a better use of whether Yamaha
I hope I can solve your concern
Greetings Franco Dosil
Hola Clark, le paso el link para que descargue el manual de usuario de su Yamaha, en la pagina 115, aparece todo lo referente al uso y conexi?n multizona y en la pagina 117 indica como seleccionar las fuentes de sonido para las zonas 2 o 3
Le recomiendo que lea detenidamente esta parte del manual, para lograr un mejor aprovechamiento de si Yamaha
Espero logre solucionar su inquietud
Saludos Franco Dosil
https://it.yamaha.com/files/download/other_assets/6/318716/RX-V3800_E.pdf
https://in.yamaha.com/files/download/other_assets/8/318718/RX-V3800_RTL.pdf
1helpful
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Yamaha Receiver RX-V3800 Rear Left surround click sound
It's possible it is some sort of interference pickup, but another possible I've come across a number of times on Yamahas is poor earth connections via the back panel.
All the circuit boards have earth connections on them and the screws holding them to the back panel form an earth bonding connection. Tighten all the screws on the back to eliminate this possibility. Costs nothing to try and may just solve it.
How do i connect my yamaha cx-1 preamplifier to my yamaha rx-v3800 av receiver
Not sure what for but through the tape monitor jacks I think unless you have pre/main jacks. Why another preamp when the receiver already has one?
5helpful
Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Multiple speakers on zone 2 0r 3 speaker output terminals
I wouldn't hook anything up except what Yamaha recommends to the speaker output terminals. That's pretty much asking for trouble!
barneyluc
No sound when using Panny plasma with RX-V3800
Let me see if I understand. You have one HDMI cable linking your TV and AVR? This is only to send video and sound out to your TV from the AVR you will not be able to send sound back over this same cable. You'll have to use the TVs audio out and connect it to an input of the AVR. The "HDMI out" on the AVR is just that Out and not In. For more questions I'd recommend checking out the RX-V3800 RX-V1800 thread over on AVSforum.com
3answers
Yamaha RX-V800 Zone 2 Operation
yes it works great. hook them up to zone B. then below the power button is a A/B button. select button B and then zone B will work.
heres the manual if it helps
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
