Refrigerators Logo
Posted on Jun 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My jennair maytag frig model number JCD2295HES keeps freezing up on me. If i shut it down for an hour or two then turn it back on it is ok for a few days or so then it happens again
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Jun 28, 2011
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10844725
Points
101584
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
1helpful
Has stopped freezing and cooling.
if compressor is working you will hear it. Take panel off and vacuum the area get all dust and debris of compressor and coils. This dust causes heat and will keep your frig from cooling. If that doesnt work try shutting down for about 6 hours like a defrost and restart.
Maytag top freeze freezes food in the refrigerator section
this used to happen to me, it is accualy the ice macine make sure you empty the ice compartment regularly
The water to the ice maker continues to drip then freezes up.
the loud noise is from the water freezing and hitting the fan blade in the freezer, is the imkr level? have you replace the filter if has one? is it hooked to an R/O water drinking system? if so remove the filter in frig. last thing to do if others questions ok if the shutoff to that water line going to frig is on the bottom of the pipe shut all the way off then turn back on if you have a dispenser and water is really slow to come out this may clear up the low water pressure. If on most units if you do not have appx 35psi it will not allow the valve inside the watervalve to seat and allows water to dribble by
Ge frig does not freeze on freezer side
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Samsung frig stopped cooling-
most new fridges have a self defrost mode once or twice a day because the coils ice up if it collects alot of moisture. it shuts the compressor down and turns on a heat coil to defrost (which can take up to a half an hour). usually on a timer that is adjustable.
1helpful
Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
Hotpoint Frig not freezing
Your refrigerator has a defrost timer inside the fresh food compartment and we need to place a flathead screwdriver through a small opening or plugged opening and turn the timer slowly clockwise until the refrigerator stops running. Allow it to stay in that area for 30 minute and the refrigerator should come back on. If so we will need to replace the timer part number WR9X502 if you want my help you can email me and chat here. Or visit my site and enter model and or part number into the model search feature, model number CTX14CYBBRWW Thanks, Sea Breeze Email [email protected] Site http://servicepartstec.blogspot.com/ Site 2 http://appliancepartsandtechnicalservices.blogspot.com/
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
JennAir SxS JCD2289AES follow up Unit stopped cooling in September. Evaporator iced up. Replaced Adaptive Control Board. Problem solved-for one night only. Next morning only lights work. Have studied...
If the unit was freezing up, then the start relay and overload did not need to be replaced.
Chances are, the defrost heater(s) are burned out on the evaporator. Confirm your Make and Model number to me and I will get more info to you.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
