This is the step for full format of your phone please rate me if i help.. Just follow what ive said
turn off the cp, hold the following buttons ( call, * and 3 ) then turn on the cp without unholding the said buttons until the nokia logo ends.. hope it helps
YOU NEED TO FORMAT YOUR PHONE NOT MEMORY CARD.FORMATTING THE PHONE WILL SOLVE YOUR PROBLEM.AND TO AVOID PROBLEM IN FUTURE INSTALL APPLICATIONMANAGER ON YOUR PHONE AND WHENEVER YOUR PHONE SAY MEMORY FULL JUST USE THIS SOFTWARE TO COMPRESS MEMORY.
THERE ARE TWO METHOD TO DO FORMAT NOKIA HANDSET.
MANUALLY.
OPEN MENU>SETTING>PHONE SETTING>FACTORY SETTING.
PRESS O.K. A MENU WILL POP UP LIKE YOU LAST ALL YOUR DATA PRESS O.K.
IT WILL ASK FOR CODE ENTER CODE( DEFAULT CODE IS 12345).
PRESS OK IT WILL DO FORMAT YOUR PHONE.
2. USING CODE.
DIAL *#7370# ON MAIN SCREEN.
A MENU WILL POP UP LIKE FORMATTING PHONE.
PRESS OK IT WILL ASK FOR CODE ENTER 12345 AND PRESS OK
IT WILL DO FORMAT FOR YOU.
3.METHOD NO.3(FOR S60 SERIES MOBILE)
SWITCH OFF YOUR PHONE.
WHILE SWITCHING ON PRESS THREE BUTTON AT THE SAME TIME.(1.GREEN DIALING KEY 2.*KEY,3 KEYPAD NO. 3 KEY) WITH POWER ON BUTTON.
A MESSAGE WILL POP UP LIKE FORMATTING. HOLD BUTTON FOR 3 SECONDS AND RELEASE THEM AFTER THAT.
YOUR PHONE WILL RESTART AND ALL YOUR DATA WILL BE GONE
hey frnd your mobile software is corrupted you have to format you mobile by using flashing softwares here is the simple tutorial to formate the mobile <a href="http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.html">click here</a>
<div><br /></div>
<div><a href="http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.htm">http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.htm</a><br />
<div><br /></div>
<div>or if you dont have knowledge of this you can take your mobile to nokia service center they will format the mobile and will charge 250-300 rs.</div>
<div><br /></div>
<div>hit thanks if you like</div></div>
You need to format if you dont know it.
How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones.
Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone. 2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key. 3. While holding these buttons, press the power button and switch on the phone. 4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone 2. Now Press following key sequence *#7370# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message. Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
CAUTION: if u have any valuable data on ur phone plz dont try this .
first charge ur battery until its full
next switch ur phone on while pressing the green key ,the 3 key and the * key.
hold these till a screen saying 'formatting' comes
allow it to format
it may take 5 mins
dont remove battery or phone system will bcome corrupted
try and format your cell....its a simple procedure just turn off your cell and then press 3 * and the call button together and then holdin these three in place turn on ur cell n do keep them pressed till u dont see a screen sayin formating or ur phone doesnt start. the problem with this is u vl liise all ur information on the phone memory... if even this not work then get it checked may ur screen needs to be changed
Format Your Phone By following Methods:-
1) Enter *#7370# & press the send key as this will do the Software reformat
if the problem still persist try method below
2) Turn off ur phone....Hold Green key, * key & 3 at the same time turn on the phone...the Total format of phone
Just make sure you're hold the three keys down firmly during startup. Don't let go until you see "Formatting ..."
