The disc that comes with the viewty is compatable with any CD-ROM drive as you open your CD tray you will see where a normal disc would fit into the tray (big circle) and there should be a place to put the small discs, witch is in the centre of the disc tray, if this has not helped you in any way then go to the LG's website and find a download for the LG suite
Yes, you can connect your phone as modem to your laptop. you will require a software called the lg pc suite before you can do so. It comes in form of a disc or you can download it from the site, then you connect your phone to the computer using the lg to computer USB cable, then you browse using the pc suite.
There are several ways by which you can do this. You can do this by inserting the disc that came with your phone when you bought it new. In some cases, if you do not have a disc, all you have to do is to visit the official samsung website and download the pc suite for samsung phones.(make sure you download the one compatible with your operating system). When you download and install the pc suite, it should also install the drivers for all samsung phones automatically and when you connect your phone, you can use your pc suite to browse through your phone. Hope this was useful to you? Please comment for more information and thank you for using fixya
To upgrade your phone's software you can follow these easy Steps :
Connect the phone to the computer through the USB Wire.
select 'PC Suite' on your phone and it should automatically open LG PC Suite III.(if you haven't got LG PC Suite III - then it SHOULD download it for you automatically, also i provided you with the link to download it below.)
After this you wait a couple of minutes (about 3-5) to let is properly load.
let it look for updates for you LG PC Suite and for your LG phone.
click on -> Tool and then *Phone Upgrade*(on the PC Suite).
Optional :If you want to update your LG PC Suite then you click on -> Help and then *Update*.
Wait something like 5mins before its comes up with a small message
saying something like 'New Update Available' - or something like that.
Color changes on the display mostly occurs because of a faulty VGA cable or a loose connection of the cable to the VGA port at the back of your PC or Monitor. But if the cable is fixed securely at the back and the problem still persists, slightly move the cable's wire segment while observing its reaction on your monitor. Does it change colors while u do so? If it does even when the cable is securely plugged in to both the PC and the monitor, then u need to change the cable. As for the visible display area size (technically called the Resolution) right click on an icon free area on the desktop and click Properties. At the top of the form click on the Settings tab. At the bottom of this form find Screen Resolution and adjust it to it your requirements and click Apply. On the confirmation dialogue that pops up click Yes if the displayed resolution suits u otherwise click No and try another resolution size. Hope this helps.
hi..It is available on your product size itself.
Just mention ur product name and the model
number in the site,it will list u with various
options.From that u can select the pc suite
which supports ur product.It is available on
the net.
check it out..
thank u..
rate me..
Hiya.. what model phone do you have, what OS are you running? Does it have Bluetooth/infrared... if you are running an updated comp with Vista and phone is failrly new they are sometimes, not always... infrared compatible, otherwise...
Normally you need a compatible USB cable from phone to computer to up/download your files.. as well as the necessary disc to install the drivers for the phone! The disc normally comes with a software suite included, if it doesnt and only has the drivers, you can normally download the appropriate phone suite from your mobile phone manufacturer. Expect to pay approx £10 if you are UK.
Thanks so much, being totally blonde today
