EliteGroup L7VMM2 Motherboard Logo
Posted on Aug 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bus ram TEAM 512 bus 333 fo T2341 Emachines
I Added ram TEAM 512 bus 333 for Emachines T2341 but CPU-Z only display bus 133 that's Why? main Support bus 266 CPU AMD Atholn 2300+
Anonymous
Level 3:
President:
  • Master 2,351 Answers
  • Posted on Aug 24, 2008
Anonymous
Master
Level 3:
President:
Answers
2351
Questions
Helped
1591074
Points
6609
The max memory speed you can run in the T2341 motherboard is PC2100 = 266MHz memory. You can see the specs here at this link; http://reviews.cnet.com/desktops/emachines-t2341/4507-3118_7-30464489.html?hhTest=1
The max bus speed is 266MHz & memory bus is also 266MHz.
The bios dropped your current memory speed down to what it could handle for incompatible memory. In your case its running the memory at 133MHz. Replace your memory with PC2100- DDR266 DIMM's. (Like these; http://www.memoryx.net/ememt2me12.html ).
Mike
EMACHINES SPECS FOR A T3025
OK
We are in the motherboard category, so I will just list the specifications of the motherboard,
The eMachines T3025 Desktop PC uses the FIC AU31 motherboard.
First International Computers (Inc)
Also known as the FIC K7M-NF18G,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
In the list on the left side, click on the blue -> FIC AU31
This is a Zip file, and the motherboard user manual.
[ A Zip file is a compressed file. It is used to send large amounts of information, more easily.
The file needs to be decompressed, or 'unzipped' ]
After you click on FIC AU31, a small window will come up -
Opening AU31_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the small circle to the left of Save File.
A small download window will come up.
Allow the file to download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. AU31_manual(1).zip, to the right)
In the next small window go to the far left, and click on -
Extract all files. (Under Folder Tasks subheading)
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
(That's it. DO NOT make any changes in the second small window.
Just click on Next, Next, and Finish)
In the last small window DOUBLE-click right on the file name.
You are now looking at a PDF file, of the motherboard user manual.
1) Processor Socket:
Socket A.
Also known as Socket 462,
http://en.wikipedia.org/wiki/Socket_462
B) Processor (CPU) Support:
AMD Athlon XP, and AMD Duron processors.
AMD Athlon XP processors that are 1500+ to 2800+, and have either a Front Side Bus of 266MegaHertz, or 333MHz.
(Front Side Bus = FSB)
AMD Duron processors that are from 800MHz up to 1300MHz. (1.3GHz)
http://en.wikipedia.org/wiki/Athlon_XP#Athlon_XP.2FMP
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
C) Motherboard chipset:
Nvidia Crush 18G, plus MCP AGP set,
http://en.wikipedia.org/wiki/NForce2
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_chipsets#nForce2
D) Ram Memory:
Two ram memory slots. (The ram memory slot that is closest to the Processor, {CPU}, is ram memory Slot 1. Also known as DIMM 1)
TOTAL amount of ram memory is 2GB.
EACH ram memory slot amount is 1GB.
Uses either DDR Sdram at 200MegaHertz, or 266MHz, or 333MHz, or 400MHz.
That is PC1600, PC2100, PC2700, and PC3200; respectively.
Bear in mind;
Ram Memory typically operates at HALF of the Processor's FSB.
Ram memory MUST be;
Non-ECC
Unbuffered
Uses 2.5 Volts.
(JEDEC set the voltage standards for DDR Sdram at 2.5 Volts.
This means the default voltage for ram memory, set by the factory for this motherboard, is 2.5 Volts.
I don't see any features in BIOS Setup, for changing the voltage parameters, for Ram Memory.
You CAN set the FSB support for the Processor, however.
There is a jumper to the Left of the Northbridge chip, and bottom/left of the Processor socket.
Set the FSB support for the Processor, at either 100/133Mhz.
or 133/166MHz.
See Page 7 (Adobe Reader page number box at Top)
Bear in mind that AMD processors are 'Double-pumped'.
100MHz = 200MHz
133MHz = 266MHz
166MHz = 333MHz
Also on Page 8 - Install the CPU, there is a statement;
"The mainboard has built-in Switching Voltage Regulator to support CPU Vcore autodetection.
That is, It has the ability to detect and recognize the CPU voltage,
clock, ratio and enables users to set up the CPU frequency from the BIOS Setup Screen.
Users can adjust the frequency through Frequency / Voltage Control of the BIOS Setup Screen."
That should be in the -Advanced Features Setup - menu.
Page 21.
The manual doesn't discuss it on Page 21, or anywhere else through the manual. (To my knowledge)
You'll have to go into Advanced Features Setup menu, and look around.
Or we can go through this menu together, posting back, and forth in Comments.
E) Graphics expansion slot:
AGP technology,
http://en.wikipedia.org/wiki/AGP
http://www.hardwaresecrets.com/article/AGP-Bus-Tutorial/155
Can support AGP cards that are either AGP 4X, or AGP 8X.
Doubt you will find an AGP 4X graphics card, and if you do you don't want to use it, anyway.
Use AGP 8X graphics card. It will be 0.8 Volts.
For additional questions please post in a Comment.
Regards,
joecoolvette
1helpful
MB keeps beeping 1 long beep no boot.
Hello try to download the manual:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=4&m=CUSI-M&os=&hashedid=n/a
Select windows xp and open the manual folder
Click on global for download.
Unzip the file and you need adobe reader to read the content.
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
This mainboard uses SD ram and it sounds like a ram problem.
If there is room for a ddr ram block you can`t use SD ram and DDR ram simultaneously.
Try to insert the old cpu again and upgrade the bios to support a bigger cpu. Not all cpu is supported.
Good luck
Can i chage my processor pentium 4 to core2duo my motherbourd is(MSI PM8M-V H (MS-7104 v2) thnkz
No, you cannot upgrade to a core 2 duo with that motherboard because it is a socket 478.
I upgraded my memory RAM 2g and added 1g so it makes a 3G of ram but how come when my pc boot up up i can only see 2G ram single chanel. wen i go to my my computer----properties----general under computer:...
Could you please go online and in a search engine type "MAX RAM E-Machines (here put your model #)." Pick a link that secribes your maxi,um ram and if it's only 2GB you'll have your answer. If the max is higher there should be instructions on how to set the computer to acess and show the RAM.
Regards,
Selk
The sound on my L7VMM2 motherboard is not working.
First of all which operating system is on the machine?
Secondly have you been into the BIOS to see if the on-board has been disabled. To get into the BIOS restart the computer and press either the Del or Esc key to access the BIOS.
Also go to device manager and see if the audio has been disabled from there.
If you have installed Windows 7 or Vista then there could be a chance that the motherboard drivers are not designed for the operating system. If that's the case then no driver will work.
You would have to manually search the internet for someone who may have found a compatible driver.
Regards.
I have a eMachines T2082 Inc. L7VMM2 Main bdBoard: KM266-8235 Bus Clock: 133 megahertz BIOS: Phoenix Technologies, LTD 6.00 PG 02/23/2003 The Hard drive access led got disconnected, do you know what pins...
This is the support page for the board. Scroll to bottom of page and download the manual which contains the location of the hard disk LED pins. Thanks Mike
Which slot to place one memory stick in to boot using only one stick of ram? Emachines T2341
slot one if it does not boot up then use the next slot slot two make sure you have the right memory for the machine
Hav K7T266 Pro2 motherboard, can not get it to go past turning on
Lorna,
to change bus to 133 MHz, you need to unlock the speed by setting a corresponding jumper on the board to assign busspeed by bios. After doing so, you need to clear CMOS and reboot. Next you'll have to set speed and multiplier in bios. Ideally: 900MHz = 100 x 9. Alternatively: 133 x 6.5 If that doesn't help...check if your RAM-modules are any good anymore. When RAM is not functioning, CPU-error code may be presented, since CPU cannot read/write to RAM, therefore not function. Let me know how this turns out.
Kind regards,
Stephan
2answers
I want to know if SDRAM and DDR@ are the same thing?
No SDRAM is single data ram, with 2 slots in the bottom and DDR is double data ram, with one slot at the bottom.
Top EliteGroup Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
