I have kitchen aid model KHHC2090SSS0 microwave. How do you replace the turn table driver ps990920.? My wife did something to partially melt ours. Other than that micro wave has been great and still runs but not well (not quiet) with damaged driver. Any manuals available?
KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Does it have the option to turn the turn table off if so turn it off and see if noise goes away if so turn table motor very common over time it will default back to on on next cycle
That may be called the turntable coupler or turntable support or roller ring assembly.
You can find helpful exploded views and part numbers at the link below, by replacing XXX with the full model number found on the tag on your microwave (not on the service manual).
My wife noticed a strong smell of something burning inside our home. Luckily we were home. The microwave was NOT on...and the turntable was turning and making that grinding sound. When I opened the door, the turntable kept turning....all digital lights were OFF. The microwave does not work. I am extremely angry that this unit was able to continue to grind unnoticed. If we were not home, I assure you that this would have caused a kitchen fire. The upper inside portion was extremely hot to the touch and the cabinet on top of the over-the-range microwave was also very hot. This would have easily caused ignition and a subsequent kitchen fire. I am going to report this to the UL.
It might be worth saving. I've worked on these for years.
Please contact me directly for full details since FixYa doesn't always inform us of follow-up questions. Remind me of the full model number and FCC ID number from the tag and your detailed symptoms.
- William E. Miller, AS-EET [email protected] http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
If everything on the microwave works, except the turntable, this could be a simple turntable drive motor failure. It does happen from time to time. This motor gets a workout as it runs each and every time you use the oven. I just want to reassure you that these DO wear out and should not be an indication of the quality of the oven. I've had to replace them before. The motor costs about $34 at searspartsdirect.com. That is...if your model number is correct. You will need to go to the web site and type in your COMPLETE model number. There are several Kitchen-Aid models listed with the number you provided. I managed to scroll through several of the part listings and they all seem to be consistent with identfying the motor you need as item #11 under the "Oven Cavity" heading. The part number is W10159107. This is a fairly simple repair job. You shouldn't have to uninstall the oven if it is cabinet mounted. All have to do is unplug the power source and remove the panel covering the underside of the microwave. The plastic spindle just pulls off the motor shaft. Let me know if you need further assistance. I hope this helps you.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
