Nokia N900  Smartphone Logo
Posted on Jun 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Phone wants me to enter lock code while i didnt set the lock before.my son entered the lock that he cannot remember.
Anonymous
Level 2:
  • Expert 171 Answers
  • Posted on Jul 09, 2011
Anonymous
Expert
Level 2:
Answers
171
Questions
0
Helped
32981
Points
544
Every Nokia phones has master code. And you can calculate that using your imei number. Just tell me your imei no and I will find out your lock code.
  • 1 more comment
  • Anonymous Jul 28, 2012
    Can you please help me find mt master code. My imei code is 356938/03/316182/0
  • Manu Neil Jones
    Manu Neil Jones Apr 07, 2014
    can you help me find my master code please.. my IMEI code is 357923040240394
  • dinesh verma
    dinesh verma May 08, 2014
    356938033109191
1helpful
Locked out of an iphone
keep entering the wrong code possibly and it should have a forgotten password .so you have to enter the apple id credentials to reset, or possibly apple i tunes has a way to restore it back to factory settings?
Feb 17, 2014 • Cell Phones
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Security code
Mostly all nokia phones have a full phone lock along with a keylock.
To enter a security lock, you need to activate it first.
for this,
go to your settings-> phone settings and scroll down to security keyguard. Then switch it on in case it is off.
Note: in case your phone locks at this moment, the default keylock is 12345 to unlock
After this you need to put in a new password to the security keylock
For this, Go to Settings-->Access codes--> Change Security code
Enter the default keylock i.e. 12345 . Then enter a new password which you will remember. Verify it by entering it again.
After you have done this, go back to settings->phone->Automatic Keyguard
Switch it on and enter the time for the keylock ( can be 5,10 or 15seconds depending on your choice)
After all this is done, you are good to go. Just remember your passcode.
My phone lock is on and I dont know the password because my son locked it what can I do.
If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the last four digits of your phone number. If that doesn't work, press - and enter your 6-digit security code instead. NOTE: Your phone's 4-digit unlock code is originally set to 1234. The 6-digit security code is originally set to 000000.
How do you set a passcode for a Sony ericsson j108a so that only I can use my phone
You can stop unauthorized use of your J108a phone by activating phone lock protection.
After activating, you will be asked to enter your phone lock code every time you restart the phone.
The default phone lock code is 0000 (zero-zero-zero-zero). It is recommended that you change this to any four-to-eight-digit personal code.
Note: It is important that you remember your new code. If you forget it, you need to take your phone
to your local Sony Ericsson retailer.
To activate the phone lock:
1. Select Menu > Settings > General > PIN codes > Phone protection > Protection.
2. Select 'On' if you want to enter a lock code every time you start the phone, or select 'Automatic' if you want the code to be entered only when the phone restarts after a new SIM card is inserted.
3. Enter the phone lock code (0000 by default) and select OK.
To unlock the phone:
• When 'Phone locked' appears, enter your phone lock code and select OK.
To change the phone lock code:
1. Select Menu > Settings > General > PIN codes > Phone protection > Change code.
2. Enter the old code and select OK.
3. Enter the new code and select OK.
4. Repeat the code and select OK.
This solution was taken from Sony Ericsson J108a user guide which can be downloaded at:
http://www.sonyericsson.com/cws/download/1/835/750/1284993225/J108i-J108a__UG_EN_1241-2576_1.pdf
I changed the phone lock code and cannot remember it .It is not locked to one network. I just cannot remember the phone lock pin on start up. If I remove the sim, the phone will work but not make calls...
hi ,
if you dont remember the code its so hard to open your phone and the only best thing that you can do is go to a certified mobile technician and read it by their gadget called z3x samsung or nstpro...but there is also a trick that you didnt spend a single cents BUT all data in your phone will be erased..if you are ready to that here is the tricks...
: power on unit (w/ or w/o sim)
: when enter lock code appear press end call, and SOS will appear
: dial 112 or any emergency number in your country
:when the operator speaks enter this number *2767*3855#
after that ,your phone will reboot and your phone lock is gone..
i hope it will help you ,thanks for trusting fixya
3helpful
How do I unlock a Samsung SGH E840 that has a self set password to get into the phones functions. When you switch the phone on it is the first thing you see. My son set the password and now can't remember...
try this for free:1. ENTER on the keypad *2767*3855# (wait 10-15 seconds) phone will reboot(restart)
2. When phone completes reboot ENTER *7465625*638*00000000*00000000# (should enable network lock)
3. NEXT ENTER #7465625*638*00000000# (should disable network lock)
4. AND THEN *#7465625# to check the locks
and if it still lock u can unlock it via imei,not free:http://www.ust-online.com/
1helpful
Plz help me
first enter ##3283# on the main screen as a phone number.
a scren will appear, scroll all the way down to Advanced.
then another screen will appear, go down to Lock Code and hit the enter button.
the current lock code will appear
remember it!
then go to settings/tools
go down to More...
then go down to Security and enter the code that u were to remember
then go to change lock code
thank u
rate me
3answers
Locked k750i
If your son locked the device, unless your son can remember the code, you are out of luck to get your info off it. Your phone will work if it gets flashed at your local service center or the provider. They should do it under warranty. If you run into any problems, or there is no service center in your area, just check my profile and im sure we can help you.
4answers
"Phone Lock Code"
u can get the puk no from the service provider , enter the wrong pin code thrice , it will ask u for this puk code , enter the code , make sure u arrange the puk code before this process...
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
