Cell Phones Logo
Posted on Jun 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i accept the incoming call for myphoneTW1, it gets hard to accept such call, its ringing what button should i use to receive it.
Anonymous
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 98 Answers
  • Posted on Jun 27, 2011
Anonymous
Expert
Level 2:
Filmmaker:
Answers
98
Questions
0
Helped
24137
Points
326
When answering the call scroll down the screen and you will see the button "answer" and "cancel" on the upper screen.
I hope this information will be helpful. Thank you for using FixYa!
Please vote if it helped you.
Phones do not ring with incoming calls
Check make sure ringer is turned up,push speaker button then push volume button a volume thing should show up on the screen,keep pushing volume button and it will. Increase the volume.ty.
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Already have unplugged everything twice and still will not accept incoming calls. The phone rings once and cuts off. Sometimes the single ring is heard only on the outgoing phone not on the incoming call...
Try reset the phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, see if this fix the problem.
Jun 22, 2011 • Cell Phones
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
No Incoming or Out going Faxes Out going faxes
Press Setup Button on front panel of printer
Scroll to Fax Settings ( Or Advanced Fax Settings )
You will find ECM ( Error correction mode )
Turn it OFF
Try to receive Fax, IT should work
4helpful
2answers
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
2helpful
How can I change the Rings to Answer setting to one ring?
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1.
Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
How do I set up my X7170 to receive a FAX?
Link
Receiving a fax You can choose to receive a fax automatically, manually, or through an answering machine.
Note: For your All-In-One to receive a color fax, the machine from which you are receiving must also support color faxes.
Automatically Recommended for a dedicated fax line
Your All-In-One automatically accepts incoming faxes using the automatic answering mode. When the Auto Answer light is on, the All-In-One receives a fax after the specified number of rings set in the Options menu.
To set a number of rings for the automatic answering mode:
  1. On the control panel, press Mode repeatedly until Fax is selected.
  2. Press Options until ANSWER FAX WHEN appears.
  3. Press + to choose After 1 ring, After 2 rings, After 3 rings (default), or After 5 rings.
  4. Press Select.
  5. Make sure the Auto Answer light on the All-In-One is on.
When the number of rings that you set is detected, the All-In-One automatically receives your fax.
Manually Recommended for a shared fax and telephone line
You can choose which incoming faxes to accept by setting your All-In-One to manual answering mode.
  1. Make sure the All-In-One Auto Answer light is off.
  2. Press *9* on the telephone after you answer the telephone and hear fax tones.
  3. Hang up the telephone.
The All-In-One receives your fax.
Answering machine Recommended for a shared fax and telephone line
To receive a fax with an answering machine connected to your All-In-One, set the answering machine to answer incoming calls before the All-In-One does. For example, if you set the answering machine to answer calls after 3 rings, set the All-In-One to answer calls after 5 rings.
  3. Press + until After 5 rings appears.
  4. Press Select.
When a ring is detected, the answering machine picks up the call.
  • If a fax is detected, the All-In-One receives the fax and disconnects the answering machine.
  • If not, the answering machine completes the call.
Note: You must set up the equipment as shown in connecting to an answering machine.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
