With batteries fully charged the camera will not turn on when you slide it to turn it on. This happned without any reason.Can you help me camera was dropped and now battery door is loose-when connected to wall charger the green light flashes & the screen says "connected to ac power-beginning to charge battery then the battery symbol appears and the screen goes black. the green light flashes & a red light beside the view window flahes but very dim. but if you hold down the button w/ the camera symbol and press the down arrow at the same time the red light flashes very bright until the button is let go. Once the camera is taken off the ac power cord it does nothing
I TURN THE CAMERA ON BUT THE IMAGE DISPLAY WILL NOT TURN ON
The batteries probably need to be replaced. Be sure that any batteries seat properly and tightly. You may have to tape the battery door shut with strong tape to keep the contact tight. This type of damage is expensive to repair compared to the cost of the cameras. You can take it in and have it looked at, but be sure to get an estimate and then you can make an educated decision on whether to repair or replace it.
Best wishes to you and Thank you for using Fix Ya!
i slipped dropped my camera and now the front of its loose and it wont turn on! help me!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
