SOURCE: Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
SOURCE: Tapes 4 years or older won't play - blue screen/no audio
Answer is No. 2. You probably had light clogged heads and by running couple of tapes, you have cleaned it somewhat. Now complete the cleaning using a new head cleaning tape. Run it for about 10 seconds but not more and you'll be ok. It is recomended to clean head by professional soon. Technician will be cleaning each head manually and you would be sleeping well for a lot longer. -James
SOURCE: Sony Handycam Dig 8 doesn't recognize tape when trying to record
If it has memory stick, Make sure your memory stick is in. Your memory stick is full. Delete the unwanted pictures from the memory stick or use a differnt biger memory stick.
I looked in the manual. It seems your camcorder does not have a slot for memory stick. But you may still save pictures on the tape. Here is the link to download the manual
http://www.docs.sony.com/release/DCRTRV140.pdf
Please read Page 40 "recording picture on the tape".
GOOD LUCK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: playback
when I plug in the RPU DC cord from my camera to the input on my tv I get nothing. Is my input jack bad or what. Also, if I tried the s video jack from the camera to the tv, would that work??? I don't know what the AV out jack is for I don't have a cord for that
