Sound like you have a bad trigger on the gun. Does gas spray when you pull the trigger? Check the wire plug that goes from the pistol to the unit. It should be under the liner hose where it connects to the machine. Then use a voltage meter on the wires going to the drive feed motor, and see if you get current when you pull the trigger. If gas doesn't spray neither, sounds like you got a bad trigger switch
