My motorola verizon droid global 2 is blocked and it is asking me for my e-mail and password but i dont know it. is there any way i can un-block it maually?
You can unlock Motorola Droid 2[A596] easily by using an unlock code.You can get this code at reasonable cost from ClassicUnlocking.com with easy step by step unlocking instructions.
Hi PUK code is called as PERSONNAL UNBLOCKING KEY. Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause. To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider. While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code DONOT enter the PUK code several times wrongly,It will block your sim card permanently. This PUK code is FREE. You no need to pay any sum to get the PUK code Thank You.
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
There is likely a process or application that is preventing your phone from turning all the way off, or it is turning your phone back on for its own purposes. Check the permissions of your installed apps to make sure none of them have that permission, and talk to Verizon to see if the recent upgrade may be causing the problem.
AsSallam o Alikum.. I want motorola droid 2 country code... Model: A955DEC: 268435459407733074HEX: A000002275FF52I want the country code to unlock my phone.. Thank u...
If you have a Motorola Droid, I'm assuming you're with Verizon. If you're with Verizon, the only instance where I could see you needing a code is if you have setup your Google account with their new 2-step account verification system. If that's the case, you'll need to log into your Google account online, https://www.google.com/accounts/ManageAccount, click on "Using 2-step verification", then click on "manage application specific passwords". There you'll create a password just for your Droid.
Sounds like your mic is either blocked with debris or broken. If Verizon doesn't
replace it for you, you can get the microphone module at Droid Repair and there is a guide
that shows you how to put in the part at Droid
Repair Guide.
