Canon ZR65MC Mini DV Digital Camcorder Logo
Posted on Jun 26, 2011
Having a problem with getting the tape to eject from the camera, the tape area will not open to eject
Anonymous
Level 1:
Genius:
  • Contributor 1,812 Answers
  • Posted on Jun 26, 2011
Anonymous
Contributor
Level 1:
Genius:
Answers
1812
Questions
0
Helped
251243
Points
49
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
It says condensation and wont work
This normally is cause from of course condensation got wet or damp, and some times it is just that the tape area needs cleaning. Best thing first is try to new tape, then of course make sure it is dry, leave cover open and camera in warm area, if not then needs cleaning. mike
1helpful
I have a NV-DX110B about 11 years old. I'm getting
Your camera appears slightly older than mine so I will do my best for you. Have you tried ejecting the tape with the power off? If I have problems I slide the eject button when the camera is off but plugged in and the tape can be ejected. I suspect the tape mechanism is in trouble. When a tape stuck in mine I had to literally force the cover open. But this is a last resort.
Give my suggestion a try and apologies if you have already tried that...
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
2helpful
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
My tape will not eject!!!
u must to open ur camera and eject motor u put 3 dc volt then it eill eject and clean all connect then fixit and try
6helpful
2answers
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
2helpful
Tape compartment won't open
eject the tape by disconnecting the power adaptor and removing the battery. After waiting a short time and then replacing the battery, the tape would eject.
5helpful
Eject
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
1helpful
Will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
