How to Defrag a Dell Computer
1. Open the My Computer window. To do this on a Dell computer, click on the "Start" button at the bottom of the screen. Then, click "My Computer".
2. Choose the hard disk drive that you want to defrag. Locate the section entitled "Hard Disk Drives." In this section is a list of hard drives on the computer. For most Dell computers, the hard disk drive you will want to defrag is Local Disk (C:).
3. Right-click on the hard disk drive you want to defrag on the Dell computer. If you want to defrag your C: drive, then right-click on "Local Disk (C:)". A menu bar will appear.
4. Click on "Properties." "Properties" is the last option on the menu bar. This opens the Local Disk (C:) Properties window.
5. Click the "Tools" tab. The Tools tab is the second tab in the Local Disk (C:) Properties window. The tabs are located on the top of the window.
6. Click the "Defragment Now" button. The "Defragment Now" button is in the Defragmentation section of the window. This opens the Disk Defragmenter window.
7. Click to select the disk drive you want to defrag on a Dell computer and then click "Defragment." For most Dell computers, this will be (C:). After you click "Defragment," the Dell computer will first analyze the disk drive you selected and then beginning defragging the Dell computer.
8. Wait for the "Defragmentation is Complete" message. If you have not defragged a Dell computer in a long time, then the defragging process might take a while, even as long as an hour for very fragmented Dell computers. Allow the Dell computer to run the defrag until the process is completed. You will know that the Dell computer has completed the defrag process when the "Defragmentation is Complete" message appears.
9. View the defrag report and then close the window. If you want to view the defrag report, click "View Report." Otherwise, click "Close" to close the window.
windows run box type defrag. (simple no?)
h3ll tell Cortana, say defrag.
omg easy
google shows 1 million hits
is that why they say google is your friend.
also on topic, updated apps for Defrag can even move the boot files for windows in the fastest tracks of the drive,(smart defrag)
if you want windows to boot faster.
but buying SSD is the best cure of all.
getting off the Slow HDD is best .
run box , type defrag. (wow)
if upgraded to SSD drive it will be grayed out. by design. (as all mine are)
