Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer
however, your whirlpool duet washer needs a reset to resolve the control lock
problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to
reset the control. Please get back to me if you have any other questions.
Kevin
I appreciate your post, philip hunter!
From my understanding the control panel on your Electrolux range is locked. On the control panel you should see a button near a lock symbol, typically it is labeled control lock, and if you hold that button down for three to five second it should release the control panel. If that does not help release the panel I would suggest performing a reset and you can do that by disconnecting the power from your range for ten minutes. Hopefully this helps. -Matt
