Hi,here is my simple solution...
to listen your TV on your Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input "
or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to
respective mode on Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
SOURCE: no sound from back surround speakers
I resolved the problem by going in the dec mode (page 49 of manuel) and changing the setting to Pro Logic. That did the trick. Good Luck all.
SOURCE: i can not find the audio out jack on my 47 inch
You might name the model of the TV.
If the TV is a monitor it doesn't have any audio capabilites. What you should do, and owners of monitors must do, is get the best digital or analog audio from the same source the TV would get it - cable/sat/dvd/bd/game.
There is nothing to be gained by washing hi-fi multi-channel audio through a TV's sub-par audio electronics and turning it into grainy analog audio for consumption by higher-fi audio-specific equipment..
