Master
- Posted on Jun 26, 2011
Re: How can i transfer built in memory card to memory...
Hi bacayemilita,
I think you meant that you need to transfer your images from your camera's built in storage to your external memory card.
Please follow the below steps :-
- Connect you camera to your computer via the USB cable and then switch your camera on.
- Once you switch the camera on you will find an option for mass storage mode , please select that option.
- Remember to remove the memory card from your camera while you do the above step.
- Once you select the mass storage mode , you will find a removable drive being displayed in my computer , in this drive you will find all your images, so all you need to do is copy them all to your hard disk drive.
- Now if you want to copy these images to your memory card , you can either do it via connecting your memory card to a card reader and copy the images from your hard disk onto it Or you can connect the camera while keeping the memory card in , and you will find another removable drive for memory card , when you select mass storage mode.
- When you find the drive , just simply copy the contents from your hard disk to your memory card's removable drive.
Hope this helps ..:) Your feed back would be greatly appreciated.
