When trying connect dc olympus fe170 with usb cable to pc, on the display of the camera displays a msg 'one moment', then the screen turns black. pc doesnt react in any case. what suppose to be the problem? (usb cable works, so is the usb port). OS Win7 (on XP - all that works)
i know this, but i hope someone to help me find what r these drivers that e missing or corrupted? the OS is freshly installed after all...i know this, but i hope someone to help me find what r these drivers that e missing or corrupted? the OS is freshly installed after all...
You can't post conmments that contain an email address.
i know that - i hope someone to help me find out what r these drivers that r missing or corrupted. after all the OS is freshly installedi know that - i hope someone to help me find out what r these drivers that r missing or corrupted. after all the OS is freshly installed
Check the LCD screen of the camera. You should get a message when you first plug it in to select the usb type. highlight PC and press ok. The screen should display one moment please then go off. Then the camera should be recognized by the computer.
If I understand your problem right, the installed Olympus program does not launch (start) when connecting the camera to the computer using the Olympus' USB cable.
1. For the program to start automatically, the camera must correctly being recognized by the computer. Check if this is the case! When connecting the camera to the computer, you should see information shown on the camera's display! 2. If not, try to connect the camera on another USB port, or better another computer to diagnose the problem. 3. If the camera is recognized, you can set an option in the program to autostart the program when connecting the camera to the computer. 4. If it does not help, reinstall the program.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Remove the Software Restert the Computer Plug camera in and turn on set it to the upload mode. Windows will then fid it via the Camera/Scanner Wizard. If there is still a problem A cheap card reader will do the trick
With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the selection screen for USB. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. There are instructions available at our web site (http://www.olympusamerica.com/download). For editing and managing image files with a PC, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the USB cable provided.
With the camera turned off, connect the USB cable to the PC and plug the smaller end into the camera. The camera will turn on and display the USB selection screen. Use the arrow keys to select the PC option and then press the OK button. The camera will be recognized by the computer as a removable drive. To edit and manage images with a computer, install the Olympus Master 1.0 software from the supplied CD-ROM. After installing the software, connect your camera to the PC via the provided USB cable.
