Cameras Logo
Anonymous Posted on Jun 26, 2011
Good evening, I have bought a Canon EF 50mm f/1.8 Mark ii lens to use with my Canon 5d Mark ii camera, and I have problems using it: - after mounting it, and switching on the camera, I have no problem using it, with or without the auto-focus, and take a first shot, - once I have taken the first shot with ViewFinder, ViewFinder goes all black, and the only way i can take further shots is via LiveView mode only. this is quite annoying, and I am not sure where this comes from. If I unmount the lens and remount it, the same happens: I can take one shot with ViewFinder but then only with LiveView. This doesn't happen with any of my other lenses (24-105mm, 17-40mm, 70-200mm) Any help on this matter would be greatly appreciated.
  • Anonymous Jun 26, 2011
    Thanks do this, but how come it happens only with this lens and not any other one?
    What can I do about this?
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Jun 26, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2197864
Points
38521
If the viewfinder goes black after one picture, the mirror is stuck in the up position.
    Thanks do this, but how come it happens only with this lens and not any other one? Is it coming from the lens? The body?
Canon 50mm 1.8 error 01
Have a look here
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/#err01
Seems to be a connection problem Clean to connectors on both the lens and camera with a pencil eraser.
Does my Sigma 28-105 mm Aspherical for film camera work on my Canon 5D Mark III?
If the Sigma lens mount is a Canon FD fitting then you can get an adapter FD to EF that will allow you to use the old lens in manual mode. If your camera isn't designed to take EF-s lenses then they will not fit on the camera. My EF-s lenses will not fit on my 6D.
1helpful
What are lenses that are compatible with the canon eos 5d mark ii
You can use Canon EF lenses. Be careful not to use EF-S lenses, as they cast a smaller image circle for cropped-sensor cameras, not big enough for full-frame cameras.There are other third-party manufacturers that make lenses with Canon EF mounts, such as Sigma and Tamron. Each manufacturer has their own designation for cropped-sensor lenses, so you'll have to check the specifications for each of them.
1helpful
I have a Canon battery grip for my Canon EOS 300D but have no manual to tell me how to use it as the camera is 2nd hand, can i get a manulal or download one from anywhere
I understand there isn't a manual, just a quick how-to guide. Here's some basic use info from a review
http://www.the-digital-picture.com/reviews/canon-bg-e6-battery-grip-review.aspx
The Canon BG-E6 Battery Grip is designed specifically for the Canon EOS 5D Mark II as shown above with a Canon EF 16-35mm f/2.8 L II USM Lens mounted. To get the Canon BG-E6 Battery Grip into the position shown, the LP-E6 Battery is removed from the 5D II and the battery door detaches. The BG-E6 slides up into the battery compartment and locks into place via the tripod socket screw seen on the BG-E6 just below the lens in the above image. The BG-E6 provides its own tripod adapter threads - this functionality is not lost.
The Canon BG-E6 Battery Grip holds two Canon LP-E6 Batteries that deliver double the number of shots or video time from the 5D II. Alternatively, use 6 AA batteries in the included Canon BGM-E6 Battery Magazine shown below.
All of a sudden i can't see anything through my viewfinder on my canon 5d (not Mark II) even when I look at a bright light (then it is only a dim blur). It does take photos which appear on the LCD, but I...
Do you find that if you slightly loosen your lens you hear a click or something releasing. Then when you lock the lens back into place u can see through the view finder, but only for 1 photo. Then it stays black again?
Can i strip and clean the inside of my Cannon EF 50 mm 1:1.8 II
I don't think so. the lens is held by 3 or 4 internal plastic hook clipping type . send it to canon cost about 30 bucks. one clip breaks, you can say goodbye to your lens.
Err.1 of Canon lens
Maybe that's why it was for sale on Ebay.
1helpful
2answers
Canon 50mm f/1.8 lens is not focusing.
I had the same problem with my ef 50mm 1.8. I used it on a cold day and broke off one of the internal gears. I used it for almost a year before I got the guts to take it apart and fix it. There are instructions online on how to take it apart, scary at first but not that hard overall. I used a small drop of crazy glue on the gear, put it all back together and just like new.
Ef 50mm f/1.8 II not auto focusing
You need to send it in for service. The more you use it with the "noise", the more you are potentially damaging the auto-focus drive mechanism of the lens. The sound you are hearing is most likely the gears and whatnot grinding away at each other because they were knocked out of place by the impact of the fall. I don't know how much this will cost, but I would say somewhere in the $200 range would not be unbelievable. Sorry I don't have any good news, but I have "bounced" a lens or two in my time.
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
