Question about Sharp KB-6024MS Stainless Steel 1000 Watts Microwave Oven
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
  • 591 Answers
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Posted on Jun 25, 2011
  • Tommy
    Tommy Jun 25, 2011
    some times magnetron antennas (the part that produce microwaves) starts to leak high voltage before they go bad and produce an ionized smell, if it's the case, buying a new oven is cheaper than to replace the magnetron unit...
  • bob55today Jan 10, 2014
    The strong ionized smell could be magnetron antennas overheating before they fail. Best to replace the whole oven then to try to replace the failing magnetron antennas component.
    New Friend:
We have a sharpe drawer microwave that started to have an electrical burning smell - it turned out to be a relatively simple repair to replace a thermistor and some charred wiring. Sharpe recommended an approved repair shop we had to take out hte oven and bring to them. Total cost $80 to fix.
Posted on May 12, 2013
My microwave starts running when you open the door how can i fix that
It is supposed to. It is designed that way. It put the light on and the extractor fan to remove steam and cooking smells. Some have a timer that continues to run for a few minutes after cooking. It is not emitting the cooking radiation when the door is open. The are at least three safety devices to stop that.
Oct 06, 2017 | Microwave Ovens
The fan on the one day old Oster Microwave runs after finished cooking. All cardboard has been removed.
It is supposed to run on and will stop on its own as long as the door is closed. The purpose is to remove steam and condensation, plus smells from the cooking cavity and cool down the magnetron (the part that emits the microwaves).
Nov 23, 2016 | Oster Microwave Ovens
My Frigidaire oven model feb386wech emits a burning plastic smell when heating up and cooking. What's causing this?
After 16 years of service, the oven may be starting to consume itself. I have found melted light fixtures and scorched, brittle wiring. If you can't isolate the source of the smell, it could be time to replace.
Nov 13, 2016 | Frigidaire Microwave Ovens
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
MY MICROWAVE DOESNT HEAT UP FOOD JUST COOKS
Hi.
The wave emitting part inside the microwave oven is called the magnetron. The waves emitted by the magnetron generate heat in food. When the microwave is running, turntable turns and light comes on but there is no heat it means that either the magnetron is faulty or the magnetron is not getting power. When the magnetron is not getting power parts such as the high voltage diode or capacitor must be tested or replaced. Testing and repair must be carried by a technician. Here some general troubleshooting: http://www.fixya.com/support/r2096491-microwave_works_normally_but_not_heat
Regards.
Ginko
Sep 07, 2011 | Microwave Ovens
Sharp R-520KS - When the door is opened, the light and fan comes on and the carousel rotates. I don't know if microwaves are emitted. How can I stop the fan from coming on and the carousel from...
You can tell if microwaves are being emitted if you get warm standing in front of it (seriously). But I wouldn't recommend that unless you want to cook yourself.
First thing that comes to mind is the door interlocks are out of adjustment or bad. Home microwave ovens are not supposed to operate like that. Some commercial models start the fan right away and run it after the cooking cycle is completed but I've never heard of a consumer model that does that.
Find your closest servicer here and have them take a look.
Sep 04, 2011 | Sharp R-520KS Microwave Oven
Is there anything we can do to remove the smell of burned food from the microwave? The smell has permeated the inside of the unit and emits the burned food smell whenever it is used.
I've adviced you to placed charcoal inside the unit overnight or when it is not in used.
Charcoal will absorb the upleasant odor from your microwave oven.
Thanks for using fixya...
Jan 09, 2011 | Whirlpool Microwave Ovens
R-308KW unit emits a high pitched whining sound when started on cook mode. Does not seem to cook.
sounds as if the magnetron is dying,the only other thing it could be is the large main power transformer,but they usually have a low growl when mag is drawing current,also it could be a loose mechanical joint setting up a mechanical harmonic,but i'll bet its the mag...good luck
Jul 12, 2009 | Sharp R-308KK / R-308KW 1100 Watts...
Microwave turned on when empty
The magnetron will be damaged and now emit low output as there is nothing to absorb the energy.
I would dispose of it and get a new one.
Sep 01, 2017 | Panasonic NN-T783SF 1350 Watts Microwave...
Sharp KB-6024MS Stainless Steel 1000 Watts Microwave Oven Logo
3,395 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
