Go to your local auto parts store.Ask at the counter,give them your make and model and year.
High & Low Beam Headlamp Light Bulb Size: 9007
Parking Light Bulb
Front Turn Signal Light Bulb Size: 7507 Or 2827
Rear Turn
Tail Light Bulb Size: 7443
Stop Light Bulb
High Mount Stop Light Bulb Size: 7506
License Plate Light Bulb
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size:
194NA
Rear Sidemarker Light Bulb Size: 7443
Dome Light Bulb Size:
DE3175
Trunk/Cargo Area Light Bulb Size: DE3022
The bulb is in a socket which will twist out,then there may be a clip that holds the bulb in.
SOURCE: Driver side headlight bulbs burned out on 2003 VW Golf
There is a light cover in front of the battery... take this off and then look for the metal clamps holding the light housing in. (I say clamps, but they're more like glorified paper clips on either side of the fixture.) Press in on each side, pushing the clamps towards each other and pull the fixture out.
SOURCE: 2001 subaru outback headlight not working
chapmnfarm: your head lights use a "2" fuse system.
one for the left and one for the right.
The fuse box you are looking for is under the hood on the passenger's side. It is a black box roughly 8 inches long and 4-5 inches wide. When you remove the cover, you will see fuses and relays. What you are looking for is the section in the box which has a cluster of 7 fuses. 3 in one row and 4 in the other. On the outer parameter are two relays. The fuses you are interested in are located in the row of 4 fuses, with the two closest to the "L" shaped part of the box. Both of those should be 15 amp fuses.
The fuse below those should be a 20 amp which is the lighting switch and the one below it is a 15 amp which is for the interior lights and the clock.
Check your harness grounds in the engine compartment near the area you have the problem. There are ground wires which come out of the harness on both sides of the core support. The wires are black in color and have "EYES" crimped onto the ends of the wires. Both of them will probably be located about 4-6 inches below the upper tie bar on each side of the radiator. Odds are that the eyes will be large enough to pass a 6mm bolt through.
I hope what I have given you will resolve your problem. Lem me know,,good luck>>>>>>>>>>>>>>>
SOURCE: Headlight bulb replacement for 2002 Hyundai
http://www.autozone.com/autozone/repairinfo/common/repairInfoMain.jsp?targetPage=productsHowToInspect&leftNavPage=productsHowTo&pageId=%090900c15280213e7e&subtitle=replace
SOURCE: Low beam, driver's side headlight
The low beam bulb needs to be replaced. Go to an autozone store as they will sell you the bulb, and even assist you in their parking lot with installing it.
SOURCE: How do you replace a Drivers side headlight bulb 2006 kia spectra
Helps to remove the battery, but small ahbds can do it.
Directly behind the lens is a big round cap ... twist it off. The bulb is held in place with a spring that locks in to a notch in the holder. When handling the new bulb, don't touch the glass. The oil from your skin will cause it to shatter when turned on.
