SOURCE: Blackberry bold 9700 Bluetooth problems
Many quirky behaviors for these
devices are fixed every time a new software version is released.
You might check that you are using the most current system software for
your BlackBerry Bold 9700 Smartphone.
The
latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
SOURCE: BLACKBERRY BOLD 9700 will not zoom before i snap a
Turn off your phone, take out the battery and wait a couple of seconds. Then reinsert the battery and turn on your phone. It should work now.
SOURCE: forgot password,just reset my blackberry bold 9700
i typed in a wrong password 10 times and my blackberry automatically wiped off most of my data, how do i restore them please
SOURCE: blackberry bold 9700 showing app error 523
With regards to your issue, error 523 reset means a "System process died" You'll neeD to reload the entire handheld OS again.
Here is how you go about it;
1. Install the software from the CD (that you received with the device), or download it from the service provider.
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes
Problem solved
Thanks and take care..
SOURCE: my blackberry bold 9700 is
Dear user,
The reason of the white screen of , you install third party software , that soft ware is not compatible with your Blackberry ,
First you have to remove that software , or if your device is not booting , then you have to format your device and upload new Blackberry OS with desktop manager .
I hope it will solve your problem
