Make sure that the feed hose floats are properly attached and spaced. Make sure that the opening at the end of the sweep hose is not blocked. You might also need to adjust the power to the pool cleaners sweep hose. To adjust the motion, turn off the booster pump and turn the sweep jet clockwise to increase motion.
SOURCE: The wheels on my Polaris
There are a couple things that you should check with these pool cleaners if the wheels are functioning properly. Check the filter screen in the in-line filter assembly and clean if necessary.Make sure that you do not have any debris or obstructions that could be halting wheel function. Even though you seem to have plenty of water, check the RPM and make sure they are between 28 and 32.
Jessica - READ the owners manual before giving wrong advice.
Rpm are 32-36.
if the unit rpms are ok, look at the water management system for debis by first removing the bottom covers 3 screws then the 3 screws holding the roundish module (WMS) with the tail attached. remove the WMS, remove the 4 scews holding the back cover inplace noting how it comes apart (spring,o ring and thrust jet).
Check that the jets (3 x venturi jets,thrust jet and tail) are clear.
If ANY debris are found in the unit, then you have a problem with the filter found either in the quick disconnect fitting or inline housing.
