SOURCE: how can i activate GPRS and MMS setting for my china mobile phone
hi there,
here i post some procedures you can follow for activation your GPRS and MMS.
Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text “ACTIVATE” and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: “Sun GPRS”
APN: “wap”
Select SUN MMS
Account Name: “Sun MMS”
APN: “mms”
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: “Sun MMS”
Homepage: “’http://www.mmscenter.suncellular.com.ph”
Data Account: “Sun MMS”
Connection Type: “HTTP”
Proxy Address: “202.138.159.078”
Proxy Port: “8080”
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select “Sun WAP”, Select “Edit Profile”
Rename Profile: “Sun WAP”
Homepage: “http://www.suncellular.com.ph”
Data Account: “Sun GPRS”
Connection Type: Select “HTTP”
Proxy Port: “8080”
hope it will help you to solved your problem or still you have any question regarding on it that you can't understand you can go on this site and log on.
http://www.kokeytechnology.com/gadgets/cell-phonesmobile-phones/how-to-activate-gprs-and-mms-of-nokia-phones-powered-by-sun-cellular/
SOURCE: HOW TO CHANGE THEMES? (china phone nokia 6300)
our main problem is the OS installed...so we have to know where and how we can replace the OS installed in our china phones...i'll post here immediately once i get a solution.
SOURCE: IN NOKIA 6300 GPRS SETTING
My solution is required another nokia 6300 that no this problem and need program NOKIA PC SUITE.
first you should backup setting from this phone via nokia pc suite
after connect your phone 6300 that have config problem to computer
then restore the setting from backup to your phone after restart your phone and enjoy.
SOURCE: how to open the GPRS on nokia 6300
Just call on sevice center of your sim card and then ask for GPRS setting.Then they will send a setting to your handset.Then click option and save. the GPRS will activate soon.
SOURCE: how to unlocked a security code for china phone
there are places where you can unlock cell phones.
